Holden 6 - Problems starting
_UCV80_
Posted 27 February 2010 - 11:41 AM
Has Fuel pressure and fuel in the carby
Has spark in all 6 cylinders and new plugs
Has oil and oil pressure... eventually (had to use vaseline) cranked without plugs for about a minute all up after i got pressure
Timing is on 0 degree on compression stroke (not 180 out)
No vacuum leaks
Its not even trying to fire at all
Is it possible that the lifters have bled down and valves arn't opening?
Possibly weak spark? (iv tried 2 coils)
Is it safe to try the coil from my uc Torana, Its an Electric ignition msd blater coil. Ok for points? Has 11.5V @ the coil in the lh
What am i doing wrong? haha
Any help is much appreciated
Posted 27 February 2010 - 12:07 PM
If you used vaso to get oil press up you may have impeded the canals(while cold) and lifters arent represurizing after bleed down.
You tested each plug is getting spark , but what colour was the spark?
Posted 27 February 2010 - 01:25 PM
I have pulled a working stock 202 engine out of my LH and have now put it all back in and i just cant get it too start. Looking for any other ideas you guys might have. I have spent too long trying and its driving me nuts lol
No vacuum leaks
Try dumping about 10mls of fuel down the carby and see if you get some action.
I couldn't start a 253 recently that had been sitting for a while and wouldn't fire. I checked everything as you have done, even thought it may have flooded as could smell fuel vapour from the exhaust pipe. Finally checked and found the carby accelerator pump stroke plunger was not pumping properly (plunger washer dried out and shrank). Dropped 10mls fuel down its throat and instant mumbo. Had to repeat procedure a few times until I could get the engine to idle.
Dave
Posted 27 February 2010 - 02:16 PM
Second, as above, if you have spark then dribble some petrol down the carb and crank again.
_nial8r_
Posted 27 February 2010 - 02:25 PM
_UCV80_
Posted 28 February 2010 - 09:50 AM
I haven't touched it since yesterday morning so i'm going to do more tests today. Dennis (slr_goat) came around and we diagnosed that the spark was very poor. Its got plenty of fuel and it sprays up out of the carby right into both of our eyes (used to working on holley's). I picked up another coil yesterday so ill put that in.
I assumed the Vaseline would be filtered before entering the oil gallery's, I always worry that vaso could block something up.
The fuel may be old too, looks like premium petrol (yellow) but its alot darker then usual. has been sitting for about 4months. So I will put 10ml of new fuel down the hatch.
Hopefully I can get it running today, thanks for everyone's help
Posted 28 February 2010 - 12:15 PM
You say the spark is weak...points and condensor ok?
Posted 28 February 2010 - 12:17 PM
_Gunmetal LH_
Posted 28 February 2010 - 07:27 PM
_UCV80_
Posted 01 March 2010 - 06:56 PM
Thanks for your help
Posted 01 March 2010 - 07:22 PM
It kind of sounded like it tried to start to run but the battery was too weak and its turned over quite slow. It also back fired out of the carby consistently each time I tried to fire her up. (what does backfiring through the carby mean) Im sure its on TDC on compression stroke and i put it on about 8degree advance.
If your getting a blueish spark , thats good.
However Ive always found back firing thru the carb is a result of incorrect timing or lifters not pumped valves dont open enough so too much
compression building in cylinders and cranks slow
_UCV80_
Posted 01 March 2010 - 07:58 PM
I should have slid in a mild cam with more lift lol
cheers,
Posted 01 March 2010 - 08:03 PM
I know you say you've checked it but maybe your balancer has slipped?
As you crank, turn the dissy clockwise and see if it starts to spin easier and maybe start to fire?
Edited by rodomo, 01 March 2010 - 08:07 PM.
_oldjohnno_
Posted 01 March 2010 - 08:32 PM
Don't worry about the lifters, it'll still start fine even if they're bottomed right out.
Charge the battery so you can spin it at a decent speed.
While the battery is charging double and triple check that the timing and firing order of the leads is correct. One of these is wrong if it's consistently coughing back through the carb.
Drain the carb and clear the fuel lines of stale fuel. Refill with fresh fuel or set up a temporary supply.
If all the above is OK and you have spark it will start straight away.
Posted 01 March 2010 - 09:41 PM
_UCV80_
Posted 01 March 2010 - 10:37 PM
Ill try everything said above and let you know how i go tomorow.
Thanks heaps for everyone's help
Cant believe i have had so much trouble with a simple 202 lol
Cheers,
Nathan
Posted 01 March 2010 - 11:22 PM
Posted 01 March 2010 - 11:28 PM
Still being a pain to start eh. Sounds like timing is out. Backfire through the carby is most likelya timing issue. Pull the rocker cover off and make sure the valves on No.6 are on the rock, and sight top of piston No.1 through spark plug hole with a torch to be sure of TDC. Another method is to insert a screwdriver into the spark plug hole and feel the piston reach TDC. This will confirm if your timing marks line up, if marks line up correct see if rotor button is lining up with post for lead No.1, if not remove dizzy and reset.
Should be a mark in the top rim of the distributor housing. Set your dizzy so the line on the top of the rotor button points to and lines up with that mark. Timing is now set to fire at TDC and the engine should start without backfire through the carby. After you get it running then you can advance the timing.
Dave
Posted 01 March 2010 - 11:41 PM
A quicker way of doing this that also saves a rocker cover gasket:
Remove the oil cap and sight the rocker forward of the hole.
This is No.1 inlet valve.
Rotate the crank clockwise and watch this valve open, then shut.
Still turning the crank clockwise, the next time the timing marks line up is N0.1 T.D.C (in the ballpark considering the balancer might have slipped) at which point you can use a probe or torch to check the piston position for balancer slip.
You can also check the key position at the harmonic balancer hub, it should be at 12 o'clock at T.D.C.
You might need a mirror.
Edited by rodomo, 01 March 2010 - 11:48 PM.
_UCV80_
Posted 02 March 2010 - 10:11 AM
You are all correct, the timing was out. Due to a slipped balancer, about 60degrees of slipping, and the piston was only half way up at the supposedly TDC. I didn't suspect this as I used a timing light before I pulled the engine out and only turned the engine over with balancer puller bolts in the centre of the balancer. I would have been trying forever without your help. Thanks heaps again!!
I have a new balancer stashed away (how convenient). I have never had to press one on before. is the best method to boil it in a pot? Ill search through previous threads about it.
Posted 02 March 2010 - 10:42 AM
If it were me, I would just use a paint pen to remark the balancer as per Rodomos diagram...that way you will be able to moniter if it is still slipping....if you felt super strongly about it...you can pull the outer ring off and put it back together in the right spot with a smear of silicon...you used to be able to rebuild by buying the rubber new.
#22
_UCV80_
Posted 02 March 2010 - 12:51 PM
cheers,
