- Where would I get the correct cross member
- Hydraulic or cable set up
- Is there anyone in Sydney that specialises in this type of conversion
- Anything else I should know?
Which Supra 5 speed is most suitable?
Posted 06 March 2010 - 08:02 PM
_evil UC hatch_
Posted 06 March 2010 - 08:25 PM
Most conversion bell housings are set up to run the original clutch release setup so you can go hydraulic or not.
Dellow are generally pretty good
http://www.dellowauto.com.au/main.html
Posted 06 March 2010 - 08:37 PM
W55 through W59 are all the same box with different ratio sets, pick whichever suits you best. R154 is the Supra Turbo box which is a stronger option if you are planning on some decent horsepower.
Thanks guys I will drop them a line.
Posted 06 March 2010 - 08:56 PM
Atleast you will be able to read the reply.
Posted 07 March 2010 - 04:30 PM
Posted 07 March 2010 - 06:34 PM
If you have more than 300ftlb of flywheel torque and use it every now and again you will eventually break the box ( often break the teeth off 2nd gear). As long as you can do all the work yourself (or are rich) and dont mind buying another box every few years then go for it.
Thanks Rexy, what is the best alternate option. I did have a VH SL/E with a very strong 308 and a Supra 5 speed and it did end up breaking.... it was a beautiful box to use though which is why I want to go back to one.
Posted 07 March 2010 - 08:23 PM
