Fitting XU-1 Caliper Spacers
Posted 16 March 2010 - 03:11 PM
Posted 16 March 2010 - 03:41 PM
Hope this helps Dave. Buy the way Repco do the kits as well.
Posted 16 March 2010 - 08:14 PM
the XU1 bolts are longer to allow for the spacers
Posted 16 March 2010 - 09:30 PM
2. Yes they are a flat seal but you can use an Oring on the spacer
3. No they don't need longer bolts... its only 3mm... but fit them if your paranoid... off to the nut and bolt shop with you
4. When you get the calipers apart you will know where the machined section (with Oring) goes
5. If they didn't sell you Orings to suit with the calipers I can see they still employ numpties
6. You may need thin spacers between the stub and caliper to centralise the caliper on the disc again ... orig cars had these... no PBP aren't smart enough to make them and supply them with the others as an actual usable kit... refer numpty remark above.
Posted 17 March 2010 - 03:48 PM
Posted 25 March 2010 - 12:40 PM
when are you going to have someone doing proper kits?
I'm sure someone would wholesale you a rubber kit to include............
Speak with sstorana........I'm sure it's something that would fit well into the product range!
Grant..
Posted 25 March 2010 - 10:37 PM
I can get the plates and spacers made
Just need to find my samples somewhere in the shed
#8 _2ELCS_
Posted 26 March 2010 - 08:49 AM
Wayne
Posted 26 March 2010 - 10:02 AM
#10 _2ELCS_
Posted 26 March 2010 - 10:48 AM
Posted 26 March 2010 - 09:07 PM
A tee bar and four foot of water pipe or not quite that tight>>>>
70 ft/lb
#12 _2ELCS_
Posted 26 March 2010 - 09:16 PM
70 ft/lb
Thanx S pack, that appears to be the best kept secret in the country..
Wayne
Posted 26 March 2010 - 10:21 PM
I would find it unlikely anyone would use a torque wrench to assemble a caliper... any caliper
#14 _2ELCS_
Posted 27 March 2010 - 09:08 AM
I could never find any thing published on it..
Posted 27 March 2010 - 09:56 AM
Not a secret now is it ?
70ft/lb is not a figure derived from any manuals etc.
Two pairs of XU1 calipers that I dismantled to replace the seals both registered between 60-70ft/lb to crack the bolts.
So when put back together I torqued the bolts to 70ft/lb. Some might say that is not an accurate way to find out the torque specs for a bolt, but without any recorded specs to work with back engineering was the only other alternative.
#16 _2ELCS_
Posted 27 March 2010 - 10:34 AM
Im sure there are engineering tables that you could cross reference torque figures for that size and grade of bolt etc...
Thanx for the info Dave..
Wayne
Posted 10 April 2010 - 11:31 AM
Lucky the car isn't registered at the moment.
Posted 10 April 2010 - 01:01 PM
split the calipers and discovered that the spacers PBP sent me were an incoplete set. the two milled spacers were milled on the same side so both suited the LHS caliper, been waiting 10 days so far for the replacment set to turn up. Been waiting 4 weeks now for the DBA slotted rotors to turn up too.
Just checked the spacers i bought from them mine are right. I got DBA slotted rotors over night last week.
Posted 24 April 2010 - 11:08 AM
been waiting since before easter for the correct set of caliper spacers to turn up. so 4 weeks and counting. Apparently they sent one set but i never saw anything and the second is yet to show either. getting pretty impatient. to make it more frustrating i ordered the first (incorrect) set over a year before i actually went to use them because i had heard they were unreliable.
Posted 15 May 2010 - 11:24 AM
#21
Posted 15 May 2010 - 08:07 PM
#22 _SableMet7/73_
Posted 16 May 2010 - 12:44 PM
Went to the local Repco yesterday but the bloke wasnt
too sure & rattled on about LHs.
Number he gave me for XU1 caliper kits was K606S, is
this right?
Jono
#23
Posted 16 May 2010 - 02:47 PM
Can also use a K785S but the channel seal is wrong
I usually use the 785 and use 9x2 mm Orings I buy from Bearing Services
But thats just me
If using spaced calipers... you need to get some extra chanel seals anyway cause theres never enough in the kit
Oh and the pistons are a DB2278 if you find you need to replace them too
Nothing to do with the spacers though
They are long gone and being laser cut by some people only
Gong was going to do these but I guess decided against them
If there is interest I'll get them made
And if someone has a sample stub spacer that goes between stub and caliper and sends me that I'll have them made too
#24 _SableMet7/73_
Posted 18 May 2010 - 12:01 AM
sorting all the running gear for one day when its painted.
I'll chase the kits up tomorrow.
Is there any of the brake pad pins available?
Think mine had large split pins in 1 & incorrect pins in the other.
#25
Posted 18 May 2010 - 12:09 AM
So its splitpins or make your own
6mm stainless I think ... but my memory is going
