2pack mixing ratios
_jabba_
Posted 15 April 2006 - 05:23 PM
_dannylxss_
Posted 15 April 2006 - 07:19 PM
_Pete_
Posted 15 April 2006 - 09:32 PM
Most Primer fillers are 4:1:1 thats probably why he recommended it, what brand are you using?. I'm asking as you would probably need to get a measuring/mixing stick with the 5:1:1 ratio on it as most mixing sticks have 4:1:1 for primers and 2:1 for topcoats on the other side.
I normally only use about 1/3 of the thinners part so it builds a bit better.
_jabba_
Posted 15 April 2006 - 10:26 PM
if you go with the tin it will dry faster in this cold weather i'll go 5.1.1 but nont mix too much at a time most 300ml just to fill the gun
Wouldnt a mix of 4:1 go off quicker than 5:1 since theres more hardener in 4:1 mix?
_jap-xu1_
Posted 16 April 2006 - 11:49 AM
mix as much reducer as you like to get the consistancy your after.
generally you wont need much reducer as the hardener thins it down a lot
Posted 16 April 2006 - 05:58 PM
out of curiosity, how much did you par for your primer/hardener/thinners?
_jabba_
Posted 16 April 2006 - 06:19 PM
Excuse my stupidity when it comes to 2pack but is reducer the same as thinners, what type of thinners do i use to thin down the mix if thats the case? Still learning about 2pack, before i get to the colour ill be picking some brains at the paint shop
Edited by jabba, 16 April 2006 - 06:20 PM.
_jap-xu1_
Posted 16 April 2006 - 06:34 PM
you still use normal thinner to wash the gun out with though
Posted 16 April 2006 - 07:06 PM
_jabba_
Posted 16 April 2006 - 07:53 PM
