1-Tonner question
_Steven72_
Posted 29 March 2010 - 04:40 PM
Posted 29 March 2010 - 05:01 PM
Ith ID plate usually gives it away.
Posted 29 March 2010 - 05:24 PM
I think you'll find a lot have been fitted with GTS fronts and HQ nose cones over the years because they look better....
_Steven72_
Posted 29 March 2010 - 05:25 PM
Edited by Steven72, 29 March 2010 - 05:27 PM.
_Woodsy_
Posted 29 March 2010 - 05:35 PM
HJ's onwards also had different internal door handles i believe, the HQ ones are like the lc lj torana? and the HJ onwards are like the LH LX etc once again, on the sedans, Utes could be different
Edited by Woodsy, 29 March 2010 - 05:38 PM.
Posted 29 March 2010 - 05:58 PM
A question regarding the original 1-Tonners Hq-Hj-Hx-Hz, they all have the same HQ style front originally how do you tell the difference???? Different mirrors, different trays??? They all look identical to me
You can't tell them apart immediately by looking. Not all HJ-HZ tonners used the HQ style front either. Special Vehicle package BO6 (Ambulance) used the equivalent HJ-HZ Premier front on both tonner and panel van. Plus you could also order another special vehicle package XY7 for at least HJ-HZ that still gave you the commercial front but had chrome grille, headlight surrounds, hub caps and bumper bar + bolts. Here is the easiest way in the absence of ID plates, to tell them apart.
HQ - HQ dash with steel glovebox front;
HJ - wide HJ speedo except where GTS dash fitted. Then look for high beam switch on floor and wipers on fascia. Also had full rat-trap clutch and big firewall harness plug like HQ but no holes for accelerator linkages as HJ used full cable. Small ID tag rivet holes except very first of HJ. Retractable seatbelt mount holes at about shoulder height in cabin (even for 1974 HJ which didn't have retractables).
HX - white needle dash, no RTS badges on guards or on dash;
HZ - RTS badges, yellow needle dash. Late HZ (approx 8th or 9th month 1978 onwards) had twin clutch pedal pivot points. Rear swaybar mounts on body. Not much else different from HX.
Posted 29 March 2010 - 06:17 PM
Posted 29 March 2010 - 06:26 PM
Edited by yel327, 29 March 2010 - 06:26 PM.
Posted 29 March 2010 - 06:51 PM
Except I've now added a temperature gauge for added peace of mind.
_beergut_
Posted 29 March 2010 - 07:33 PM
think your confusing them for the vans/utes
one tonners where like the coupes and kept the hq style front till the wb upgrade and to my knowledge the ambo pack wasn't offered
_ozbox_
Posted 29 March 2010 - 09:28 PM
[/quote]
hq coupes had hq fronts hj coupe had a hj front hx le coupe had a different grille to the hj coupe but the same style front as hj not hq...hx is where the coupes ended..
utes and vans were the same as just stated...
one tonners unless optioned otherwise with what byron has stated all had hq front sheet metal up to hz and then a complete front change for wb...ambulance pack was available on 1 tonners which gave them the hj hx hz style front..
_Woodsy_
Posted 29 March 2010 - 09:37 PM
Posted 29 March 2010 - 09:42 PM
Hqs nose cones look better so you say potta i think your on it my friend potta that is as for 1 tonner f$#^%^g ugly imho.GThis is my HJ if that helps.
Posted 30 March 2010 - 12:26 AM
Way off the mark! The only HQ-HX coupes to have HQ nose were HQ. HJ LS had HJ Premier front, HJ GTS had HJ GTS front, HX LE had it's own front but basically HX GTS with Premier nose.
Yes tonners used HQ style front, unless they were an Ambulance pack (BO6) where they got Premier front (from HJ-HZ) and also Premier doortrims and armrests. BO6 was available on tonner and panel van.
Posted 30 March 2010 - 08:28 PM
they have the same differences as there sedan counterparts....
Looks like there's more to it than this....
Seems like quite a complicated model.
Posted 31 March 2010 - 03:54 PM
That isn't a HQ nose, its not a HJ Premier nose, and I'm pretty sure its not an ambulance pack.
_ozbox_
Posted 31 March 2010 - 04:10 PM
So WTF is that on my tonner?
potta,that is the 1 tonner commercial front...which was hq based....the nose cone and radiator supports are no different to hq except that they have holes in them to take the blinkers...the grille is metal but a plastic hq grille will slide right in...the front bar and brackets are unique to the commercial front and again will fit from hq to hz...the gaurds bonnet and cowl panel are all hq....
Posted 31 March 2010 - 04:32 PM
Thanks Ozbox
Edited by Potta, 31 March 2010 - 04:35 PM.
_Steven72_
Posted 31 March 2010 - 04:50 PM
Posted 31 March 2010 - 04:52 PM
#21
Posted 31 March 2010 - 05:02 PM
I think maybe I am wrong.
Just checked wikipedia where there are two pics of a 1 tonner and a ute with the commercial fronts but normal mirrors.
http://en.wikipedia....olden_Kingswood
#22
Posted 31 March 2010 - 06:33 PM
#23
Posted 31 March 2010 - 06:38 PM
I quite often have to stick a hand out to move the mirror so I can see what I need to see....not looking forward to winter
#24
_ozbox_
Posted 31 March 2010 - 06:45 PM
#25
Posted 31 March 2010 - 06:48 PM
I spose they add value??
