383 holden reliable or hand grenade?
Posted 29 May 2010 - 06:04 PM
was always planing on a 355 but after going for a spin in afew hot cars and a good friend of mine cranking up the pace in his vh im starting to consider a 383 stroker holden
ive never heard alot about them so can some one shed some light on what the reliabiltiy is like are they likely to trow rods or have they got it down pat and ya crazy for not forkin out the extra few clams to gain more cubes
Posted 29 May 2010 - 07:10 PM
And i believe C.O.M.E are the only people that make that (correct me if im wrong as i prolly am), i have heard a few stories about them....
Posted 29 May 2010 - 07:20 PM
_Kush_
Posted 29 May 2010 - 07:49 PM
Posted 29 May 2010 - 07:52 PM
Work out the Rod ratio then go from there....Also seeing though you have to notch the block (unless its late model) for a 355 to clear the rod bolts makes me wonder how small the little end would be on the 383 kit to fit inside the engine....
_Kush_
Posted 29 May 2010 - 08:09 PM
Posted 29 May 2010 - 08:11 PM
_Kush_
Posted 29 May 2010 - 08:31 PM
Posted 29 May 2010 - 09:03 PM
Posted 29 May 2010 - 09:24 PM
_Kush_
Posted 29 May 2010 - 10:23 PM
Posted 30 May 2010 - 12:39 AM
Posted 30 May 2010 - 12:20 PM
Posted 30 May 2010 - 11:33 PM
_moot_
Posted 31 May 2010 - 08:09 AM
any motor is only as good as the guy doing it
Posted 31 May 2010 - 02:21 PM
Evan.
Posted 31 May 2010 - 05:45 PM
_moot_
Posted 31 May 2010 - 06:36 PM
_LH SLR 3300_
Posted 31 May 2010 - 07:11 PM
Posted 31 May 2010 - 07:28 PM
The same laws of physics also say you will make more torque and have better cylinder filling.
Building a 383 requires more work than a 355 but in some applications it is well worth it. Most problems can be fixed with cubic dollars.
Personally I prefer the 355, its just easier.
JMHO
#21
_moot_
Posted 01 June 2010 - 07:52 AM
#22
Posted 01 June 2010 - 04:59 PM
just started considering the 383 as its something a lil diffrent also after going for a spin in some 383 chevs
it will have vn heads with all the bells and whistles just seems like ya have to no what ya doing to build a 383 not just any monkey can slap it together
#23
Posted 01 June 2010 - 07:37 PM
#24
Posted 01 June 2010 - 08:05 PM
#25
_imperial engines_
Posted 04 September 2016 - 05:55 PM
I've just pulled a 383 apart for a freshen up. Scary to say the least. Rod ratio 1.52:1 . Crank hitting the main web. Std Main bolts. Mexican (literaly) cast pistons, weird looking conrods , COME crank- not a lot of evidence of balancing, i will have to run up the assembly in the balincing machine to check.King bearings- not the high performance ones. Sump has half the bolts missing as the pan rail area has been welded up in places so that clearencing for the rods could happen. Seems like a lot of work and a lot of stress on the block for what gain (above a 355) i'm not sure.
Anyone got anything I should be aware of with a 383?
