i found some venetian blinds out of a xf falcon wagon at the wreckers so i pick it up to modify and put in my lc.
how are these usually mounted in the back?
also i need to clean them up a bit so im going to paint them but dont know whether to go black or white.
Can people post some pictures of lc/j with white or black venetians so i can get an idea? on a yellow car?
thanks
venetian blinds suit lc/j
_dickiep_
, Jun 02 2010 11:22 PM
7 replies to this topic
_dickiep_
Posted 02 June 2010 - 11:22 PM
_dickiep_
Posted 02 June 2010 - 11:30 PM
i was thinking of doing a telescopic mounting style to hold them in place. as the add says i you dont have to drill holes.
im going to use the xf ones (cut down) cause they were $20 and it'll be a fun little project!
also thanks for the super fast reply
Posted 03 June 2010 - 01:12 PM
How are you going to cut them neatly? Just be careful so that you don't bend them because all of the ones I've seen are really fragile, and a little bit of bending will make them rub against the glass really bad etc lol. Get photos of the process anyway
_dickiep_
Posted 03 June 2010 - 04:53 PM
Heath my dad is a boiler maker (metal fab) by trade so shouldn't be to much of a stretch!
These ones seem pretty tough. If not I grabbed the side window venetians as
well.
well.
_dickiep_
Posted 04 June 2010 - 02:22 PM
cool i contact them and they are fitted by tabs that go between the glass and the rubber seal. has anyone got pic of them installed?
_dickiep_
Posted 08 June 2010 - 10:19 PM
ok im going white with them
also doing a build in my thread http://www.gmh-toran...ic=14946&st=100
should have more progress thurs when the cutting should be begins!
_sumer_
Posted 23 August 2010 - 08:18 PM
