Edited by SLR Goat, 03 June 2010 - 07:22 PM.
red 6 cylinder flywheel bolts
_SLR Goat_
Posted 03 June 2010 - 07:16 PM
Posted 03 June 2010 - 07:38 PM
just put 7/16 bolts in them, ARP 351 Nascar bolts dont need cutting.
_oldjohnno_
Posted 03 June 2010 - 07:46 PM
Is there anything special about red 6 cylinder flywheel bolts can i buy them from a bolt shop? would getting some high tensile 3/8unf bolts be fine?
Yes, flywheel bolts are special. Apart from the very high tensile strength material the hex head is grooved in a way that evenly distributes the forces/stresses. I use ARP p/n 206-2802; they're easily available. Normal grade 8's might do the job in a standard engine (for a while at least) but I wouldn't push my luck with anything that revs a bit. Socket heads (like unbrakos) are higher tensile than grade 8 but are also more brittle so again would be risky with anything other than granny's church car..
_SLR Goat_
Posted 03 June 2010 - 08:08 PM
cheers dennis
Posted 03 June 2010 - 09:40 PM
peter
Posted 04 June 2010 - 12:05 PM
_oldjohnno_
Posted 04 June 2010 - 07:54 PM
Anyway, I'm yet to have any flywheels or bolts loosen with the ARP's so I'll keep on using them..
_threeblindmice_
Posted 04 June 2010 - 08:35 PM
Mate if it makes you feel better , I have had red (street)sixes , XU1 specs or better for over thirty five years ,with no problems using GMH bolts.Cheers guys will suss out those arp bolts dont think i need 7/16 its not a big reving engine just a daily mild 186 and m20 4 speed better off being safe dont think having a flywheel come thru the floor would be fun
cheers dennis
_SLR Goat_
Posted 04 June 2010 - 08:54 PM
Posted 05 June 2010 - 01:51 AM
_SLR Goat_
Posted 05 June 2010 - 08:33 AM
6000rpm every gear change using Holden bolts
http://s48.photobucket.com/albums/f250/rodomo/Race%20pics/?action=view¤t=SandownMay16th2010045.flv
Wont get any more reassurance then that cheers rodomo
