Stereo cuts out on a beat
#1 _mello92_
Posted 03 June 2010 - 09:09 PM
Installed a 720W 4chl amp, 1000W sub and 2x 420W 6x9 speakers into the LX about 2-3 months ago, used 4 gauge cable since the amp and battery are at either ends of the car.
Within the past 3-4wks it has started to cut out on a beat, even at 1/4 volume. Turn it down a bit and you can notice all the lights dimming to the beat.
Question is: why? and why now? Why not right from the moment I installed it?
Remedy?
BTW:- Did a bit of a test the other day.
With the stereo up to the point where it cuts out, lights on highbeam, wipers on and the fan on, I get 13-13.3V across the battery.
Turn everything off and I get 13.9V.
Drive around for 4hrs or so without the stereo and I get 5-10mins at half volume.
Alternator buggered?
Cheers for the help.
#2 _luv the uc_
Posted 03 June 2010 - 09:35 PM
My thoughts only, these are based on previous problems I have had.
#3 _Skapinad_
Posted 03 June 2010 - 09:38 PM
#4 _mello92_
Posted 03 June 2010 - 09:51 PM
Adam, dont worry, you can still hear the exhaust over the stereo...cept when it works well.
#5 _robslxhatch_
Posted 03 June 2010 - 10:01 PM
#6 _mello92_
Posted 03 June 2010 - 10:10 PM
See, this is why I ask questions here!
Posted 03 June 2010 - 11:04 PM
Posted 03 June 2010 - 11:21 PM
But I dare say you need to have a look at increasing the alternator to at an 85amp VN type
and check condition of the battery.
If your having these stereo problems , what sort problems if any are you havong trying to start the car?
#9 _mello92_
Posted 04 June 2010 - 09:39 AM
Amp earth connection to the body is fine, I cant see the connection to the amp itself..its in a awkward position, will check that this weekend.
Steve - sub connections were fine mate.
The car starts fine, just a flick of the key and away you go.
And my battery earth is connected to the engine head, not the body. Should I run a lead from the battery neg to body? Why/why not?
Battery condition is good. Its a sealed type with an indicator which tells me its fine.
Archie, yes Ive read heaps about using the 85amp alternators, I understand they are a straight swap? Would I need to change anything else if I were to fit one?
Thanks guys.
Posted 04 June 2010 - 10:18 AM
battery to the radiator support panel or one of the radiator bolts.
If you think about it the main negative wire goes to engine for supply to the starter motor but the engine, exhaust,
gearbox are all tehnically insulated by rubber mounts and and thereefore the boby doesnt get a good earth.
Somehow some earthing is getting through otherwise your guages would not work and other items the car.
It could be through your gear selector, an exhaust mount hitting the body ar similar.
If your amp or any other extra devices you have added are just connected to body for earth then the connection will
not support the extra current.
There is a thread somewhere I showed what I had to do to put a VN alternator on here.
#11 _mumstaxi_
Posted 04 June 2010 - 10:29 AM
Think the others are on the right track, but dont rely on those battery indicators as a accurate indication of battery condition,they usually only work on one cell only.
MT
#12 _mello92_
Posted 04 June 2010 - 10:48 AM
Cheers Archie, looks like I will be running a lead from battery neg to body then, any particular size cable?
Ahhkk, will go hunting for it, cheers.
Found it mate, thanks for posting that.
But I have a 6cyl. Is it still a straight swap?
Edited by mello92, 04 June 2010 - 11:00 AM.
#13 _nial8r_
Posted 04 June 2010 - 04:11 PM
[EDIT] you can stilll try all that^^^^ but i just seen that you have a 720watt 4 ch Amp, which is 180 watts per channel so the Amp is suffering as it cant keep the watts up when the juice is turned up and the sub is trying to pump, disconnect the sub and see if you have the same problem with just the 6x9;s running off the Amp, then see what happens when you just run the sub without the 6x9's ?? i think you will need to run a seperate amp for the sub, i had the problem in my old 4 runner
Edited by nial8r, 04 June 2010 - 04:25 PM.
#14 _mello92_
Posted 04 June 2010 - 04:20 PM
Cheers for the input though
Im keen on getting a VN V8 alternator...
Edited by mello92, 04 June 2010 - 04:20 PM.
#15 _nial8r_
Posted 04 June 2010 - 04:27 PM
Nah, this amp is 2 months old, brand new model. I got the sub bridged across channels 3 and 4. Just one sub mate, the speakers are connected to channels 1 and 2.
i just edited my post mate have a look !!
#16 _mello92_
Posted 04 June 2010 - 05:28 PM
But I think this may make it worse...
The amp is rated at 180W bridged, so the sub is only getting 180W, speakers are only getting 90W each.
And this amp sucks...............34Amps. Eeek. No wonder the alternator is struggling. Hmm.
Remember, 720W is max output, and if its not getting the 14.4V like it supposed to, then that aint gonna happen.
Anyway, will try your elimination method tomorrow arvo.
So does a VN V8 series alternator just bolt straight in?? Wiring to suit of course.
Edited by mello92, 04 June 2010 - 05:29 PM.
#17 _Torrie_Man_
Posted 04 June 2010 - 06:21 PM
#18 _mello92_
Posted 04 June 2010 - 06:40 PM
Posted 04 June 2010 - 08:43 PM
If they are in the engine bay are they sealed?
I have seen shit fuse bases fill with crap that have caused high resistance joints on the fuse itself, causing voltage issues on stereos, especially when the load increases (read bass/volume)
May be worth a shot to just pull the fuses, have a look and maybe give the contacts a bit of a scrub with some scotchbrite or similar.
#20 _Gunmetal LH_
Posted 05 June 2010 - 02:46 AM
I'd say your alternator is ok if you have everything on and your reading over 12v across the battery...
Edited by Gunmetal LH, 05 June 2010 - 02:48 AM.
#21 _mello92_
Posted 05 June 2010 - 07:12 AM
#22
Posted 05 June 2010 - 11:11 AM
#23 _mello92_
Posted 05 June 2010 - 11:16 AM
For example: drive around for a while without the stereo; cuts out at a higher volume than if I use it all the time.
#24 _uncleian_
Posted 05 June 2010 - 12:01 PM
#25 _mello92_
Posted 05 June 2010 - 12:37 PM
And..................................................................you're shit.
Thanks for the constructive input though, seriously..................................
