Immobiliser help
_niterida_
Posted 13 June 2010 - 04:01 PM
Now the factory immobiliser is no longer functioning - no light and no beeps. Car will turn over but will not fire up.
I had an auto electrician out to look at it and they said there is a problem with the LPG wiring which is preventing any power getting to the injectors. They couldn't fix it and want the car towed to their workshop so they can spend more time on it - the workshop is about 2kms away and will cost me $75 to get it towed there !!!
SO does anyone have any ideas of what could be wrong ? I doubt it would be the LPG wiring since that was not touched and it was working fine exactly 30secs before the battery was removed and replaced. And if it is the LPG wiring why is my immobiliser not flashing or beeping. Is there any way of resetting a factory immobiliser or are there separate fuses for it somewhere ?
Any help most appreciated.
Posted 13 June 2010 - 05:49 PM
I didn't think they beeped?
Where is your flashing light that isn't flashing?
Check all fuses.
_hutch_
Posted 13 June 2010 - 06:06 PM
''A" pillar or glove box slip ya ign key or glove box key into it and turn backwards,pretty sure this bypasses the whole immobilizer
Phillip
Posted 13 June 2010 - 06:24 PM
there is a key switch iether in the lh door
Phillip
This is a switch that you had turn off to immobolise the car, then you have to turn it on again to drive it.
All it does is switch off the ignition power to the computer, no rocket science, just an extra switch.
VP had it in the "A" pillar but I think only the upmarket VN's got it, Calais etc. and it was in the glove box.
Wouldn't hurt to turn it on and off a few times though to ensure a good connection through it.
Just remember what position it was in before you start. (If fitted?)
_niterida_
Posted 13 June 2010 - 07:16 PM
I will check if their is a separate key switch too - unfortunately the car is not at home and it is my only set of wheels so I have to ride my treadly to go and check it.
I would assume the sparky checked all the fuses but I will double check those too.
Posted 13 June 2010 - 07:40 PM
_niterida_
Posted 13 June 2010 - 08:18 PM
Have a good look around the battery as well, just incase you might not of re-connected all the wires at the terminals.
That was the first thing I checked :-)
Posted 13 June 2010 - 08:22 PM
Check that too.
_luv the uc_
Posted 13 June 2010 - 08:29 PM
Posted 14 June 2010 - 12:19 AM
_niterida_
Posted 15 June 2010 - 04:00 PM
The sparky told me the immobiliser (not the key switch one) is a factory unit but he is wrong since they don't come with anything other than the key switch in the A pillar.
So I left the battery off overnight and hey presto - working in the morning - woohoo
Thanks guys.
