Are 225/50/15 legal to run on 8" rims
13 replies to this topic
#1 _Herne_
_Herne_
Posted 23 June 2010 - 05:33 PM
I think 225/50/15 tyres might just be legal on 8" rims? Am I right?
If they are legal do they look ok when looking at the wall to rim fitment?
Herne
Edited by Herne, 23 June 2010 - 05:34 PM.
#2 _Squarepants_
_Squarepants_
Posted 23 June 2010 - 06:09 PM
Ideal size for a 7" rim is 215 so I can't see a problem with 225's on 8". I actually have 215's on my 17"x8" rear rims, the side walls are on a bit of lean but they look ok... Would look better with 225's or 235's though.
I dunno what the rules are in ACT but in QLD the tyre width can't be more than 30% greater than standard and rolling diameter has to be within 15mm of standard. Therefore, on my car, in QLD, legally, I can go to a maximum of 225/40/17.
#3 _Herne_
_Herne_
Posted 23 June 2010 - 06:31 PM
Thanks mate, I thought it was ok just looking for some form of confirmation :)
Its not my preferred choice by any means but with the brand I might be using in the future I am size limited :)
Herne
#4 lxsstorana
lxsstorana
  • 2,499 posts
  • Car:SS Hatchback
Posted 23 June 2010 - 06:36 PM
They're legal and they look good on an 8 inch rim (you wouldn't want any smaller on them).
If you run a 50 series tyre on the front, then I'd recommend a 50 series tyres on the back.
I run 225/50/15 on an 8" rim on the front and 265/50/15 on a 10" rim on the rear.
The other factors to consider are ground clearance for your exhaust system, driveway etc
Mick.
#5 _rob350hatch_
_rob350hatch_
Posted 23 June 2010 - 06:50 PM
Herne
they fit nice Attached File  23062010036.jpg   308.84K   13 downloadsnot good pics but i hope they help
Edited by rob350hatch, 23 June 2010 - 06:53 PM.
#6 Heath
  • 18,401 posts
Posted 23 June 2010 - 07:12 PM
Yeah they are perfect fitment for the look and the drive quality IMO.
The typical fitment that people do on here I reckon involves too much tyre and not enough wheel, makes the tyres all sloppy laterally. Might make it better for drag racing? lol
I run 225/60/R13s on 13x8s (rear)
https://cache.gmh-to.../MOTORVATE2.jpg
Edited by Heath, 23 June 2010 - 07:13 PM.
#7 76lxhatch
  • 7,213 posts
Posted 23 June 2010 - 07:53 PM
Another yes, good match in terms of width and tyre shape. I have 225/50s on 15x7 fronts at present, they look better on the 15x8s
#8 ls2lxhatch
  • 5,335 posts
Posted 23 June 2010 - 07:54 PM
The rim calculators specify 6.0 - 7.5 for a 225/50/15.
An 8.0" rim will still be within Tyre & Rim Association of Australia specifications however if the tyre manufacturer has specified a maximum rim size of 7.5" then you would need to check if it is legal in your state.
Tyre & Rim Guidelines
Edited by ls2lxhatch, 23 June 2010 - 07:57 PM.
#9 76lxhatch
  • 7,213 posts
Posted 23 June 2010 - 08:07 PM
^ Seriously? They're starting to hang over on a 7" wheel, 6" would be awful and much less safe than 8"
#10 ls2lxhatch
  • 5,335 posts
Posted 23 June 2010 - 08:21 PM
225/50/15 Toyo T1R
Test Rim 7.0
Approved rim widths 6.0 - 8.0
Proxes T1R.pdf
Typically the range is 1.5" which is why the rim calculator specifies 6.0 - 7.5
#11 _Herne_
_Herne_
Posted 23 June 2010 - 09:58 PM
Thanks guys, that info is great and will do nicely :) Now I need to get those rims and once I have them talk to the tyre co that wants to supply my tyres :)
They saw my car in a mag and rang me (unsolicited) and offered their services.
Herne
#12 _Herne_
_Herne_
Posted 23 June 2010 - 10:29 PM
Herne
Thanks for the photo's too, exactly what I wanted and yeah I agree the fit looks good.
Al.
#13 REDA9X
REDA9X
    Removed
  • Inactive
  • Pip
  • 0 posts
Posted 23 June 2010 - 10:37 PM
I have 225/50/15 on my 8" front wheels. My old VR SS had the HSV optioned wheels which were 16x8" and the factory fit tyres were 225/50/16, so if the factory fits that size I'm sure it's legal
#14 _Herne_
_Herne_
Posted 23 June 2010 - 10:40 PM
:spoton: Sounds perfect to me :) Thanks
Al.
