caompression ratio
_75LH_
Posted 23 April 2006 - 05:29 PM
Posted 23 April 2006 - 05:37 PM
ive seen cars make power N/A with over 12:1 on 98 octane, but personally wouldnt go over 11:1 on a street motor, the days of high comp street engines are over, people make respectable power with respectable comp these days.
_Keithy's_UC_
Posted 23 April 2006 - 06:08 PM
Edited by Keithy's_UC, 23 April 2006 - 06:12 PM.
_CHOPPER_
Posted 23 April 2006 - 10:46 PM
_1QUICK LJ_
Posted 23 April 2006 - 11:26 PM
if using std cam up to 260 adv duration use 9.0-9.5 comp
270-280 adv duration 9.5-10.1
290-300 adv duration 10.1-11.5
300+ adv duration 11.5- 11.8
this is only a rough guide of what ive found seems to work well with different combos ive built for people,dont be tempted to run comp that is too high or you end up loosing any real gains by having to reduce ignition timing to suit.
_Keithy's_UC_
Posted 24 April 2006 - 02:34 AM
_[BOTTLEDUP]_
Posted 24 April 2006 - 02:41 AM
Posted 24 April 2006 - 02:55 AM
I agree with Chopper, about 9.5 to 10 would be about right.
_75LH_
Posted 24 April 2006 - 12:07 PM
_1QUICK LJ_
Posted 24 April 2006 - 02:26 PM
antelopeslr5000: dynamic compression ratio is far more important because thats what you actually end up with when the engine is running, what i quoted was static comps and what size cams suit them quite simple really.
you cant say that its ok to run 10.5 comp in every combo because one motor might have say a 270 duration cam(25/65 timing) and will rattle its head off,but a motor with a 290 duration cam(35/75 timing) will be no probs because it bleeds off cylinder pressure, then if you put in a 320 duration cam(50/90 timing) it will still run fine on the fuel but be a guttless pig due to very low dynamic comp.so the cam does matter when it comes to a running engine,which means a cam does come into deciding a static compression ratio.as does chamber and piston crown design, if you build engines with just the static comp in mind and no other factors such as cam, chamber design ,and volumetric efficency then how can you tell what comp you really need? its the old saying its all about the combo
Posted 24 April 2006 - 04:57 PM
Posted 24 April 2006 - 06:52 PM
Cams don't determine your static compression ratio, as I stated eariler, but they do play a major roll in deciding what static compression ratio to aim for.
_CHOPPER_
Posted 24 April 2006 - 07:18 PM
