XU-1 Battery
21 replies to this topic
#1 _bathurst 72_
_bathurst 72_
Posted 02 July 2010 - 03:41 PM
Does anyone know what battery fits a genuine XU-1 Battery holder and is capable of starting a high comp motor? Most batteries are either 135mm or 175mm wide. Battery holder is 155mm wide.
#2 Bazza
Bazza
    ǝɹnʇxıɟ ɯnɹoɟ
  • 4,295 posts
  • Car:ɐuɐɹoʇ
Posted 02 July 2010 - 04:20 PM
Hi
The original battery was 5 1/4 inch (135 mm) wide rated at 61 amp hours - I believe that equates to 366 cold cranking amps (cca) in modern terms. I use an Exide P310D it is only 310 cca but works fine. There are other brands that are similar. Be sure to get one with the terminals on the engine side and the negative to the front of the vehicle.
Bazza
#3 _sunburst73-xu1_
_sunburst73-xu1_
Posted 02 July 2010 - 07:08 PM
Sorry to seal the thread but Has anyone got a good pic of a Lucas battery?I know the the xu1 tappet cover thread its has a pic of the strike me pink promo car.I'm in the process of duplicating the battery and have made the top caps in which I'm happy with but I'm trying to find out what the little black and yellow decal says in the center of it and plus a better photo.
Any help would be great.
#4 WhiteA9XS
WhiteA9XS
  • 1,646 posts
  • Name:Shaun
  • Car:LJ LX
Posted 02 July 2010 - 09:44 PM
i,m surprised no one hasnt had copies of the lucas battery remade yet since its a consumable part , red top white body from memory ?
#5 _sunburst73-xu1_
_sunburst73-xu1_
Posted 03 July 2010 - 06:28 AM
I'm going for a darkist grey body for mine.
Attached File  img020.jpg   96.88K   65 downloads
#6 rodomo
  • 18,055 posts
Posted 03 July 2010 - 09:48 AM
Hi
The original battery was 5 1/4 inch (135 mm) wide rated at 61 amp hours - I believe that equates to 366 cold cranking amps (cca) Cheers
Bazza
Do you know the length and height as well Bazza?
#7 Bazza
Bazza
    ǝɹnʇxıɟ ɯnɹoɟ
  • 4,295 posts
  • Car:ɐuɐɹoʇ
Posted 03 July 2010 - 07:33 PM
Hi
No sorry, I don't know the other dimensions. I read it somewhere. Aldo has an original battery, maybe he can provide the dimensions.
Bazza
#8 _sunburst73-xu1_
_sunburst73-xu1_
Posted 03 July 2010 - 10:31 PM
Spose at the end of the day we are governed by what is available today bearing in mind the battery I picked up today was very close to what Bazza quoted in withe.
#9 _sunburst73-xu1_
_sunburst73-xu1_
Posted 09 July 2010 - 06:18 PM
Just finished my battery for my car,obviously not exact but will do me.
Attached File  101_1763.jpg   34.55K   79 downloads
#10 meanmachine72
meanmachine72
  • 2,045 posts
  • Name:Jono
Posted 10 July 2010 - 01:26 PM
looks good dane...NOS battery leads???
#11 _sunburst73-xu1_
_sunburst73-xu1_
Posted 10 July 2010 - 06:44 PM
Thanks Johnno
Not sure but I don't think so but there a very good copy.
#12 _sstorana_
_sstorana_
Posted 10 July 2010 - 09:58 PM
Dane
are those Lucas Caps the ones that scotty was telling me about? He wanted me to look into remaking them..
Mick
#13 _sunburst73-xu1_
_sunburst73-xu1_
Posted 11 July 2010 - 04:56 PM
Dane
Mick
Hi Mick
No there were ones I made up myself,I have seen the ones that Huddo has borrowed off Craig and there a fair bit different.The ones I made are abit shorter and was copying off the ones Huddo has on his car but rounded at the ends the same as the pic of the promo strike me pink xu1.
The ones that Huddo has borrowed may not fit the modern day battery and a copy may need to be modified.
Anyway talk to Huddo when he gets back I'm sure he will fill you in.
cheers Dane
#14 _sstorana_
_sstorana_
Posted 12 July 2010 - 08:59 AM
Thanks Dane
yeah, I think that it's achievable (using the top of the lucas one with the botton to suit an existing battery) as long as we don't stray too far from the original size etc.
I will wait till Huddo gets back and check it out then..
Mick
#15 _Ozzie Picker_
_Ozzie Picker_
Posted 27 May 2011 - 07:29 PM
COME ON HUDDO,JEZZZUS
didn,t realize its been this long,mr rev head
i,m going to get club rego very soon and want to add the caps.
#16 _sunburst73-xu1_
_sunburst73-xu1_
Posted 27 May 2011 - 07:38 PM
I would say he is playing utes Craig. :stirpot:
#17 _Ozzie Picker_
_Ozzie Picker_
Posted 27 May 2011 - 07:41 PM
go and kick him back into the right gear,XU-1,
not slow poke grandma special ej ute.
#18 _sunburst73-xu1_
_sunburst73-xu1_
Posted 27 May 2011 - 07:45 PM
Ha ha ha ha :spoton:
#19 dublinxu1
dublinxu1
  • 153 posts
  • Name:Brian
  • Car:73 Dublin Green XU-1
Posted 26 September 2015 - 04:24 PM
has anyone got a close up picture of an original battery cap? Currently making some up and just want to get the lip on top right.
Brian
#20 _steerslj_
_steerslj_
Posted 09 December 2015 - 09:48 AM
could anyone help with the battery type everyone is useing in the lj torana in the normal place. im having trouble trying to work out a suitable one to put in it. any help would be greatful thanks
#21 RM125n
RM125n
  • 54 posts
  • Car:TORANA
Posted 10 December 2015 - 04:42 PM
Super cheap and battery world have xu1 battery's number N41 they still have caps on top of battery like the old exide battery number P310D. The new Exide battery 43C to suit your car is now maintance free with a glass viewing panel on top. Century also has a battery number 41 Std or H/Duty 51 this one I think is maintance free as well . A mate of mine purchase a battery from battery world and purchase 6 soft drinks with dark green lids after drinking them he put a small hole in the top of caps so the battery can vent then glued them onto the N41 battery caps and a green GMH sticker on the side it made the battery look like they did back in the 1970's hope info helps.
#22 _steerslj_
_steerslj_
Posted 11 December 2015 - 12:08 PM
Thanks John for your help.
