LH Torana diff width?
_Sandman_
Posted 24 July 2010 - 08:18 PM
Posted 24 July 2010 - 08:20 PM
Posted 24 July 2010 - 09:23 PM
Posted 24 July 2010 - 10:48 PM
According to the Torana owners manual the LX rear tack is 54.4" (1382 mm and the factory rims have an offset of +1.25" ( 31.8 mm ).
In theory the diff width should be 1382 mm + ( 31.8 mm x 2 ) = 1445.6 mm although this figure does not allow for the thickness of the brake drums.
Edited by ls2lxhatch, 24 July 2010 - 10:48 PM.
_kane355_
Posted 25 July 2010 - 07:45 AM
kane
Posted 25 July 2010 - 03:42 PM
Mark
_Sandman_
Posted 25 July 2010 - 08:35 PM
Posted 04 June 2017 - 08:43 PM
Posted 05 June 2017 - 01:07 AM
At the inspection centres they measure across the tyre tread.
Posted 05 June 2017 - 11:33 AM
Posted 05 June 2017 - 12:20 PM
Get it made 25mm shorter so you can fit slightly wider tyres without any rubbing. Standard width sucks for anything bigger than 225's. .
Posted 05 June 2017 - 03:13 PM
Just be aware that if you get the diff shortened, you can't LEGALLY fit standard wheels any more since they would be under the factory track measurements.
As per NCOP Section LS Tyres, Rims, Suspension and Steering, paragragh 4.2.9 the manufacturer's wheel track can be increased up to 25mm but must not be reduced.
Posted 05 June 2017 - 03:16 PM
If your getting it made shorter... pick your brakes first... you may need to relocate the shock for caliper clearance
Posted 05 June 2017 - 03:22 PM
