ie: geometry, pipes line up, can be bolted in with little or no mods?
Sorry if this has already been covered, couldn't find anything with a search
Posted 09 August 2010 - 05:38 PM
Posted 09 August 2010 - 06:54 PM
Posted 09 August 2010 - 06:56 PM
Posted 09 August 2010 - 07:10 PM
Posted 09 August 2010 - 07:45 PM
might be a bit of overkill on a baby 202 but bomber
Posted 09 August 2010 - 07:55 PM
Edited by torbirdie, 09 August 2010 - 07:58 PM.
Posted 09 August 2010 - 08:04 PM
Hold on a sec, bomber has just suggested the same radiator as you but bombers suggestion needs no modification.
IMO convert a 6cyl crossflow from WB or early commodore to fit or as bomber suggested, 2 or 3 core chev radiator with no mods for the win.
Posted 09 August 2010 - 08:20 PM
There are two very common upgrades Im aware of which would be available at most radiator suppliers. You can get a 6cyl 3 core in the same overall package size as the standard 2 core which will improve things, or there is the larger v8 style 3 core in the chev hose config which will do a better job. The latter were standard equipment on 6cyl toranas with fact air and also were known as the HZ taxi pack radiator, not two sure if taxis were ever fitted with them as standard though.
Edited by TerrA LX, 09 August 2010 - 08:22 PM.
Posted 10 August 2010 - 12:46 PM
Posted 10 August 2010 - 06:03 PM
