Diff Oil
14 replies to this topic
#1 davelh
davelh
  • 820 posts
  • Car:74 LH SL
Posted 29 April 2006 - 02:08 PM
After some suggestions on what diff oil to put in my open wheeler 6cyl banjo diff, as i have to get under the car, and might as well change it while im there
Just been so long since ive changed the diff oil, cant remember what to buy
dave
Edited by davelh, 29 April 2006 - 02:11 PM.
#2 FastEHHolden
FastEHHolden
    Steptoe
  • 5,114 posts
Posted 29 April 2006 - 04:23 PM
any thing smelly.
Hypoid gear oil stinks...any thing that suits hypoid gears.
#3 davelh
davelh
  • 820 posts
  • Car:74 LH SL
Posted 29 April 2006 - 05:57 PM
What viscosity oil would be the best
dave
#4 barny_lx
barny_lx
  • 601 posts
Posted 29 April 2006 - 06:00 PM
I think i used LSX90 , seems fine to me
#5 _wombat_
_wombat_
Posted 29 April 2006 - 07:39 PM
as it is open center any 80/90 gear oil will do the job.
#6 davelh
davelh
  • 820 posts
  • Car:74 LH SL
Posted 30 April 2006 - 08:40 AM
i knew it had to be different to LSD oil.
Ill go get some today
thanks for the help guys
dave
#7 barny_lx
barny_lx
  • 601 posts
Posted 30 April 2006 - 10:34 AM
yeah 80/ 90 will do, but i was flickign though the castrol bok at work and it daid you can use a LS oil as well....
#8 davelh
davelh
  • 820 posts
  • Car:74 LH SL
Posted 28 May 2006 - 04:07 PM
well, i did change the oil, and fixed a leak a couple of weeks ago.
heres the thing, i used 80/90 hypoid oil, and now, when driving at low speeds, particulary in reverse, the diff is whining more than my mrs.
got me a tad worried
any ideas/suggestions
it wasnt doing it at all before i changed the oil
the oil that came out was a bit blck, but no metal came with it.
i did let the car sit for 2 weeks (i was out bush) before i drove it, but i dont see this being an issue
any thoughts will be appreciated
dave
#9 _Oldn64_
_Oldn64_
Posted 28 May 2006 - 04:53 PM
Sounds like it might have had thicker oil in it (possibly due to age.) If you push your car alot and the diff gets hot etc (ie burnouts etc) then I would go for a thicker oil and the pressures in the diff will great alot of heat. heat is a diffs enermy, and as such anything you do to assist it helps.
I usually put a 75/120 (truck gear oil) into my banjos as this allows them to last longer and has a great warm characteristic. Never Broken a bango yet...
PS: I would try the above and see, it will only cost you approx $25
PPS: How much oil did you put in?
#10 davelh
davelh
  • 820 posts
  • Car:74 LH SL
Posted 28 May 2006 - 09:45 PM
sounds good, i might try the thicker oil and see what happens
when i filled it, on level ground the oil was level with the filler hole on the back of the diff, same as i filled it last time
thanks oldn
dave
#11 _devilsadvocate_
_devilsadvocate_
Posted 28 May 2006 - 10:13 PM
Is the prob when the diff is warmed up or cold or both?
#12 davelh
davelh
  • 820 posts
  • Car:74 LH SL
Posted 29 May 2006 - 08:30 PM
it seems that the most prominent time is when i have driven home from work, and reversing in the driveway, and if i throw it back to second to keep off the brakes
i give it a little bit of stick, but no burnouts or anything
its due for a service in the next month or so, so i will just change to the thicker oil when im doing everything else
dave
#13 davelh
davelh
  • 820 posts
  • Car:74 LH SL
Posted 16 June 2006 - 01:38 PM
i am home again now and looking at doing the diff oil again this weekend
what do people think of 85/140
is this getting a bit too thick
let me know what you think so i can know before i buy
dave
#14 _Oldn64_
_Oldn64_
Posted 16 June 2006 - 02:48 PM
I have been running my diff on the truck gear oil for 4 months now with no issues. have not broken it either.
#15 davelh
davelh
  • 820 posts
  • Car:74 LH SL
Posted 16 June 2006 - 06:46 PM
thanks for the reply olden
i have been looking out for the truck gear oil you mentioned the other week (75/120) and found some 85/140 which obviously is slightly thicker
do you see any problem with this
dave
