Painting engine bay with rattle can paint.
15 replies to this topic
#1 _judgelj_
_judgelj_
Posted 06 September 2010 - 07:36 PM
Has anyone had any experience with this? I was curious as to whether it would be possible seeing as though its not as large a surface as other parts, and it doesn't need to have the same quality finish as outside panels... or should i drop the idea and go with the gun?
#2 _Bomber Watson_
Posted 06 September 2010 - 08:40 PM
No reason you cant do it.
Shit coverage, shit chemical resistance, dries to fast/goes on to slow so you will get lots of dry spots and a shit finish, more expensive than doing it with a gun, apart from that no reason you cant.
#3 FastEHHolden
FastEHHolden
    Steptoe
  • 5,114 posts
Posted 06 September 2010 - 09:16 PM
Thats a bit unfair Bomber...It will look great....for a day.
#4 _Quagmire_
_Quagmire_
Posted 06 September 2010 - 09:30 PM
um i'm with bomber
if you have the spray equipment then spray with a gun
if you intend doing more than one job just buy cheap guns and compressors as the all up cost would be around 200 bucks
and the spray cans could cost close to that alone
#5 Edk
Edk
  • 101 posts
Posted 07 September 2010 - 09:42 AM
yeah do what ya please mate, there was a thread on justcommodores where he painted his whole car with a paint brush and it came out pretty good lol
you wont get the finish like you said... you can always give it ago, if it doesnt work out just sand it back.
Ed
#6 _niterida_
_niterida_
Posted 07 September 2010 - 11:16 AM
If it is the paint job I am thinking of I believe he did it with a roller, not a brush. He then spent hundreds of hours sanding it back to get a smoothe finish and yeah it looked as good as a spray job when he had finished. Not much $$$ but lots of hours instead !!
So anythings possible as long as you do the prep work and are prepared to spend more time than $$.
I fixed a damaged front spolier and front of the bonnet on my VK Group 3 with spray cans and you would only pick the repair if you looked really close. And that was a 5 minute rush job too :-)
Edited by niterida, 07 September 2010 - 11:21 AM.
#7 _judgelj_
_judgelj_
Posted 07 September 2010 - 07:04 PM
Well i have the equipment just don't have much experience with spray guns! Painted a lot of parts rattle can style, lot of building materials as well, just not panels as such. What would be the difference between gun and can other than the way the paint is expelled? Is it a different paint? What makes the finish any less resistant as apposed to acrylic? Im just not too confident with the gun as i haven't used it, might have to do more research into using the gun/find a good thread on it. And i don't think we're talking Aussie export $2.50 cans in which case i wouldn't even bother but just thought i'd run it by some people who are in the know, be good to hear from any panel beaters!
#8 _Viper_
_Viper_
Posted 07 September 2010 - 07:23 PM
Matt or Satin black from a spray can looks... ok... but I wouldnt even bother with anything else.
#9 ls2lxhatch
  • 5,334 posts
Posted 07 September 2010 - 07:37 PM
The difference is in the area covered by each pass. It would be similar to using a 1" brush to paint the side of a house.
You can get spray cans custom made using the same paint and tint system as the paint used with a gun. I have had cans made for small touch up jobs but for an engine bay the spay gun will be cheaper, quicker and produce a better finish.
#10 _Quagmire_
_Quagmire_
Posted 07 September 2010 - 08:29 PM
24 bucks per litre vs 50+ odd for the spray can way????
um just scrool down this topics page and hunt your libary/internet/old street machine/car mags
for books and tips
and if you got a few old panels then practice on them
don't use 2 pack as it's highly toxic and a bitch to get right
i basicly taught myself and while i'm not the best spray painter around i do a competent job
it's a topic that's hard to explain but once you try it, it's easy enough to master the basics
have fun and if you stuff it up just walk away let it dry rub it back and do it over again
(hence y you shouldn't use 2 pac)
and yeah wear ppe even acyrillics/enemal paints got a punch to it
#11 _niterida_
_niterida_
Posted 07 September 2010 - 08:45 PM
not to mention illegal
#12 _judgelj_
_judgelj_
Posted 07 September 2010 - 08:50 PM
yeah i know the deal with 2K. my uncle was a backyard panel beater but got in trouble for using acrylic. hes not very helpful nowadays so ill stick with the interwebz for advice im actually quite confident/competent when it comes to application, just dont know how to use a gun :$ ill figure it out though ill find something. i found the VG tutorial very helpful! just doesnt have much info on technique etc..
#13 _Quagmire_
_Quagmire_
Posted 08 September 2010 - 10:09 AM
quick easy and not the best ...but
1) find an old panel
2)set up your gun (you'll have to find tips on this as i can't explain it on the net)
3)spray at 12-18 inches away from the point your spraying moving the gun in a even fashion and in a straight line (well just keep it the same distance away from the panel your spraying) overlapping by 50% on each pass
it's pretty much the same as spraying with a spray can but with a gun lol
practice makes perfect and if your not happy do as i said above
one trick is to put the air line over your shoulder to keep it out of the way and stop it getting into the work
if you ask nicely bomber or yudi might give you more advice as they do it for a living
#14 _judgelj_
_judgelj_
Posted 08 September 2010 - 11:43 AM
thanks, bomber actually gave me a lot of advice which i appreciate and it was really helpful. i just needed to know more about acrlic paint and gun setup but now i feel im quite confident to give it a shot!
#15 Neils LX
Neils LX
  • 2,074 posts
  • Name:a
Posted 10 September 2010 - 07:19 PM
Ed
That was a Black VN wagon, looked good when it was finished
#16 _judgelj_
_judgelj_
Posted 10 September 2010 - 10:02 PM
[/quote]
[/quote]
yeah i remember seeing that ages ago, wouldnt wanna take on that job
