so I am trying to work out what to do for a diff in my UC, I have a sunbird one in it now and I want something that is LSD what can I do.
Its onlygot a blue 6 so it does not need a 9 inch, can you make a sunbird diff limted slip or not? if so how
cheers antony
sunburn diffs?
_superlowuc_
, Apr 30 2006 08:39 PM
4 replies to this topic
#1 _superlowuc_
Posted 30 April 2006 - 08:39 PM
#2 _lx5008_
Posted 30 April 2006 - 09:46 PM
the uc torana had a small salisbury diff, same as a wb holden 6cyl diff and a early commodore 6cyl and 253v8 diff all were small salisbury. so yes you can have a lsd in your uc. the most common to find is a wb cyl diff. i know a newcastle wreaker had one a few months ago. you just have to buy the complete diff just to use the lsd centre. or you can even change the ratio if you like. due to your sunbird diff been 3.90 ratio. to a 3.36 which is the wb ratio.
#3 _MYLJ_
Posted 30 April 2006 - 10:02 PM
the small sailsbury diffs have banjo diff internals, you can use the lsd bits out of any banjo or small sailsbury to convert your diff to lsd.
#4 _lx5008_
Posted 30 April 2006 - 10:15 PM
the gears, cones etc etc are the same but the differance is the hemiphere. small salisbury and banjo are not the same.
#5 _MYLJ_
Posted 30 April 2006 - 10:49 PM
OOPS new I was forgetting something,
