hi, just want to check, are the rear upper control arms on a lh the same from left to right? thanks
lh upper rear control arms
_2wild4u_
, Nov 26 2005 11:48 PM
1 reply to this topic
_2wild4u_
Posted 26 November 2005 - 11:48 PM
Posted 27 November 2005 - 09:14 AM
Uppers and lowers should be the same for left to right.hi, just want to check, are the rear upper control arms on a lh the same from left to right? thanks
The only slight difference maybe, I know the right hand side has a small hole drilled in it for the rear brake line clamp to screw into. Not sure if they drill both sides or just the 1, but the arms seem identical.
