twin turbo carby 308
8 replies to this topic
#1 _TUFF75LH355_
_TUFF75LH355_
Posted 17 October 2010 - 07:09 PM
Hi guys just wanting opinions on a twin turbo carby 308 set up in a 75 lh torana , what im mainly interested in is your thoughts on problems or issues this setup may incounter with things such as rego issues, will the setup work , what turbos if its possible, etc etc cheers ben
#2 _Gunmetal LH_
_Gunmetal LH_
Posted 17 October 2010 - 08:04 PM
Ha! Went to reply and it got moved while I was typing...
First thing would be an issue with rego. If you could then there'd be insurance problems.
There's not that much room under the bonnet and in a draw-thru setup, unless there's a common intake manifold then you'd need twin carbies and that could be a challenge in itself getting them balanced/sync'd.
I reckon injection would be the go. Unless you go a single turbo, or twin turbo's into a blow-thru carby.
Could be done.
There's others here that would know a lot more about the specifics though.
#3 _TUFF75LH355_
_TUFF75LH355_
Posted 18 October 2010 - 12:50 PM
thats what i was planning on doing a twin turbo setup into a decent size blow thru carby . Will i have trouble with emissions etc
#4 _Gunmetal LH_
_Gunmetal LH_
Posted 18 October 2010 - 03:10 PM
Yes. That's where fuel injection would be better.
Emissions would be the least of your worries. Sorry to rain on your parade- but I doubt you'll get a 308 with forced induction passed by anybody.
The engine can only be something like 2/3 capacity of the largest engine produced in the vehicles range to allow forced induction, or the largest able to be fitted re: vehicle weight.
There's a ton of other things you'd need to think about aswell. Brakes, body strength, fuel system, gearbox/trans, diff... Many more that others would know about.
My opinion is a big single turbo would be better. A lot less complicated.
#5 _TUFF75LH355_
_TUFF75LH355_
Posted 18 October 2010 - 05:13 PM
fuel injection isnt always the answer , i had a vy ss 5.7 litre with a t51r garret turbo bolted on the side of it. It made on a soft tune 523.2 rwhp on just under 10psi, now i failed emissions testing on every test no matter what we did to the tune, no matter how many cats i use still failed... now if i had of gone twins i would have passed first go, due to where the o2 sensor locations on the single turbo setup it made it impossible to pass , and there was no way you could move the o2 sensors to make them work.
when you say brakes, body stength, fuel etc etc whats the difference between running a big single setup or 2 medium size twin turbo setup, the same mods still apply either way
my main concern is not getting the car engineered it was more or less will a twin turbo setup work through a carby system, and if so will i have to comply with emissions , even though the car and engine are both pre pollution
#6 _Gunmetal LH_
_Gunmetal LH_
Posted 18 October 2010 - 11:36 PM
TUFF75LH355- I meant that would have to be thought about aswell as the engine, regardless of whether it's a single or twin setup.
The idea of a single would be easier regarding plumbing, oil lines, balancing/matching pressures etc. in a blow-thru setup. Not that there's heaps in a VY but there's also a space issue under the bonnet in an LH.
#7 Litre8
Litre8
    Thrillseeker
  • 2,399 posts
  • Name:Howard
  • Car:1976 LX SLR8000
Posted 19 October 2010 - 08:08 AM
Licence retention may also be an issue.
#8 _mervex_
_mervex_
Posted 19 October 2010 - 10:22 AM
yes ,you can fit a single under bonnet ,no worries.fitted about 8 of them many moons ago.set up used a side draught weber,suck thru.yeah i know,flame on but they went like hell,didn't need to rev it and were nice and quiet.i will try to find some pics.
mervex.
#9 _nzstato_
_nzstato_
Posted 19 October 2010 - 11:17 AM
This was for sale here recently (though dont thing it even found a buyer)
You Tube
Not a blow through set up but might give you some inspiration
