Factory VL - VT 304 EFI heads
_CHOPPER_
Posted 23 October 2010 - 12:16 AM
_gtr-xu1_
Posted 23 October 2010 - 12:20 AM
Posted 23 October 2010 - 09:25 AM
_sshatch355_
Posted 23 October 2010 - 09:55 AM
vt combustion chambers
Posted 23 October 2010 - 12:16 PM
_CHOPPER_
Posted 23 October 2010 - 11:08 PM
The combustion chamber also evolved over the years. I think there are 3 different shapes.
But did that really make much of a difference?
Posted 24 October 2010 - 08:00 AM
_CHOPPER_
Posted 20 September 2012 - 02:02 PM
I have been patiently waiting for nearly two years now, can somebody answer this?
Posted 20 September 2012 - 03:23 PM
Posted 21 September 2012 - 08:15 AM
_CHOPPER_
Posted 22 September 2012 - 02:12 PM
_LH8VD69_
Posted 22 September 2012 - 09:49 PM
So if the VT heads have the smallest chamber, then I shall casually chase up a pair of them.
Wouldnt a bigger chamber = better? .... Just asking as I'm still looking at these options.
Posted 23 September 2012 - 06:34 AM
Posted 23 September 2012 - 08:57 AM
VN 5L =165kw @ 4400rpm Compression Ratio: 8.4:1
VT 5L = 179kw @4800rpm Compression ratio: 8.8 : 1
VT 5.7 = 195kw @ 5200rpm
GTS-R 215 kw @ 4800rpm compression ratios 8.85:1
I think the VT head would be the pick of heads if you are not going to port exc. 308 or 355 with a cam and you well be looking for a bit of compression any way.
If you want over 450 hp and you want to ports, the head man will make good power out of VN or VT heads.
At the end of the day you will proberly speen close to $3000 for good heads. So I would look at after maket heads like COME racing but you will also need to spend more money on the rest of your motor for a good resalt.
COME Racing 2010 VN-VT alloy heads...590+hp out of the box complete...$3500.00 a pair.
Edited by ACJ, 23 September 2012 - 08:58 AM.
_CHOPPER_
Posted 23 September 2012 - 02:54 PM
It's easier to make a small chamber head larger than the other way round. IF I do go down this path and use the cast iron EFI heads, it would at most run a 355 stroker and a mild cam. Just a nice stret engine. If I was chasing big HP, I wouldn't use ANY Holden block.
Posted 26 March 2013 - 08:04 PM
It might be a bit of an old thread, but does anybody know what numbers are cast into these heads? I'll probably be getting a pair next week, so it would be handy to know which is which.
_Baronvonrort_
Posted 27 March 2013 - 04:15 PM
A good thread on aussie V8 about the VN onwards heads including YT and Come alloys by HPE Pete who does a lot of porting on these heads he posts plenty of photos to show his handiwork which will help you identify what you have or want.
http://www.aussiev8....2-vn-heads.html
Posted 27 March 2013 - 08:01 PM
I think it will take me a while to read those 37 pages, but thanks anyway.
_pinklx_
Posted 28 March 2013 - 11:23 AM
ive only ever seen two differant casting numbers for efi heads allthough ive found three listed, the walkinshaw #92060145.which ive never seen, actually all the walky heads ive seen have the same casting as the vn thro to vt heads casting #92060019 in these heads vn to vs series 2 had 64cc chambers and are good for porting and the vs series 3 and vt had 58cc but are thin castings and are no good for going large.
the other number is #92060757. this is the vn group a head. totally differant castings but as far as i can tell same chamber shape and size as regular vn. the exausts are d shaped and the intakes are larger with alot more meat in the roof area, u can actually raise the intake runner so much the injector notch is completely gone. also the decks are way thicker. ive got a set that have had around 100 thou taken off them and have 46cc cambers after the were polished. these are the best efi factory heads u can get.
if i had to get a set of heads and keep costs low i would grab a set of stock vn heads send them to pavtek with directions for watever cc chamber i wanted, run them through the full race port cnc program, throw him a 1000 bucks and have heads that flow around 600hp. cheap really.
