Selecting a Cam
Posted 03 May 2006 - 07:21 PM
Im looking at maybe a 40/80 crow cam with 300/300 duration and .450"/.450" valve lift and a pwer range of 3500-6800. But then i get worried because apart from valve timing (40/80) the specs dont seem much bigger than mine, and with the crow cam list if you go lower in the valve timing you sometimes get more valve lift and/or duration and maybe go higher in the valve timing and sometimes get less valve lift and/or duration.
What i want to know is what combinations do what, what goes good with what and so on. Im just trying to get my head around cam specs.
The car is street driven daily but no real traffic work its either open HWY or residential streets but I am looking at getting into some track work, hillclimbs, sprints, motokhanas and the like.
My engine specs are 186 + .040" Fully balanced and decked with flat top pistons, Shaved Yella Terra stg 3 open chamber head running 9.5:1 comp, electronic ignition, extractors, and a 390 4bbl holley (thinking about 1 3/4" SU's)
And I am looking at the Crow range of Hydraulic camshafts
http://www.crowcams....e-Holden6.shtml
Thankyou, and all help and knowledge will be appreciated. Matt
_Torana308_
Posted 03 May 2006 - 07:52 PM
_[BOTTLEDUP]_
Posted 04 May 2006 - 02:19 AM
_LJ308injected_
Posted 04 May 2006 - 10:21 AM
regards: Steve
_[BOTTLEDUP]_
Posted 04 May 2006 - 09:02 PM
I'd be very interested to see that combo.
Edited by [BOTTLEDUP], 04 May 2006 - 09:02 PM.
_LJ308injected_
Posted 04 May 2006 - 10:27 PM
Im not a big fan of the six's although one of the only six's that has amazed me and the quickest revving engine i have seen.
Regards: Steve
_[BOTTLEDUP]_
Posted 04 May 2006 - 11:17 PM
Agree that would be a $$$$ combo, and rather intensive on the maintenance
Posted 05 May 2006 - 12:35 AM
Cheers Matt
Posted 05 May 2006 - 10:27 AM
Ive seen this covered in a few magazines in depth, but i wonder if we have any members on here who may like to put together a tech article on what is a cam, how do they work, and what do all these funky numbers MEAN...
I used to have a reasonable grasp of the works of cams, but to be hinest.. ive forgotten it all!
If anyone's got the info, or maybe i'll look into the magazine articles ive kept and try and post them up for more people to see and learn about cams.
Cheers!
_Keithy's_UC_
Posted 05 May 2006 - 10:34 AM
Mine is a city happy combination, and very highway compatible (try 8.5l/100km @ 120km/h average) as ive just driven Townsville to Brisbane and back (over 3000kms). I do suggest running thermofans as the belt driven fan simply couldnt cope with the motor running slightly warmer than the stock one it replaced... Twin 10" Davies Craig's are absolutely perfect for my combination with a 6cyl radiator...
Keith
CAM SPECS:
Duration - In & Ex 280
0.050 Duration - In & Ex 217
Cam lift - In & Ex 286
Valve lift - In & Ex 456
Lobe spread - 111
Edited by Keithy's_UC, 05 May 2006 - 10:38 AM.
_[BOTTLEDUP]_
Posted 05 May 2006 - 04:21 PM
Posted 05 May 2006 - 04:42 PM
I understand too that this knowledge is the money of any engine builder, and by no means do i want to take that away from anyone!
I was thinking of some basic info for people's knowledge ( and to stop em using that damn rediculous "Stage 58" terminology that shits me so badly!!)
_[BOTTLEDUP]_
Posted 05 May 2006 - 05:19 PM
-Dave
_MAWLER_
Posted 05 May 2006 - 06:18 PM
_Aquarius - LC_
Posted 05 May 2006 - 08:49 PM
This is a very interesting topic ! I'm not sure as to which is best.
However i can say, that the cam i selected for my 202 works
very very nicely!
It's a DYNOTEC PC206, 38/78
295deg duration
[email protected]",
.488"lift
rpm range 2200>6500
Last trip to the dyno 3 mths ago, yielded 152.8rwhp[114.6rwkw]
Like Keith's, my car is also very well manered in all situations,
Posted 05 May 2006 - 11:03 PM
_Keithy's_UC_
Posted 06 May 2006 - 09:00 AM
If its a big dollar motor, go for lift, if its a semi-budget motor, go for duration. If you want lumpy, go for duration. If you want sleeper like characteristics, go for lift... The crouching tiger theory.
Keith
P.S. Personal opinion here, and i believe it to be true.
