Temporary bare metal protection
12 replies to this topic
#1 _CHOPPER_
_CHOPPER_
Posted 26 October 2010 - 02:23 PM
I have started taking a couple of Landcruiser guards etc. back to bare metal. Due to time constraints, it may wind up being a couple of months by the time all the panels have been done. I am looking for a product that will give good bare metal protection while the panels are either in the garage or in the carport under plastic tarps. The other thing is that there would have to be minimal preporation afterwards to start painting. Cost of the material isn't a big consideration.
#2 _Quagmire_
_Quagmire_
Posted 26 October 2010 - 02:32 PM
fish oil or some other oil should work
auto trans oil might be worth a try too
just clean it off real well with wax and grease remover before painting
#3 _abtorana_
_abtorana_
Posted 26 October 2010 - 03:15 PM
gday
get some rust convertor from supercheap (either 3M or Septone) and follow the
directions and they will stay clean/surface rust free for months.
have used both types with great results.
#4 71xu1
71xu1
    Dave
  • 1,276 posts
  • Car:LC GTR XU1
Posted 26 October 2010 - 03:35 PM
Wattyl super etch 1k available in either black or grey.
Cheers Black
#5 _Bomber Watson_
Posted 26 October 2010 - 05:30 PM
71xu1 is on the money.
I was going to suggest any 1k etch primer.
I would definitely not recommend using an oil.
#6 _Quagmire_
_Quagmire_
Posted 27 October 2010 - 11:58 AM
y not bomber?
you wouldn't "drench" it in oil
just a light covering to stop oxidation (rust)
like how you buy raw steel and i did say to "prepsol" like you should before painting anyway
i agree a primer would be better but chopper wanted a quick easy non prep way of protecting them from the elements
in all reality if left under cover the rust would be sfa anyway
Edited by Quagmire, 27 October 2010 - 12:01 PM.
#7 _CHOPPER_
_CHOPPER_
Posted 27 October 2010 - 01:23 PM
Cheers Black
Is this easy to get off later, or do you just rub it back a bit and slap undercoat and then top coat over it?
Bomber, I had my doubts about using fish oil. That tends to soak in too much, doesn't it?
#8 _Quagmire_
_Quagmire_
Posted 27 October 2010 - 01:29 PM
rub it back and treat as a normal primer
i believe that's what it is?
and what bomber was suggesting
#9 _SnotGobbler_
_SnotGobbler_
Posted 05 January 2011 - 08:30 AM
im trying and using Gibbs
apparently it has all sorts of uses. did a bit of reading about it on Old holden written by the forums resident panelbeater StreatNeat.
#10 Ruts
Ruts
    How Fast!?
  • 1,118 posts
  • Car:Blown A9X replica, Black SS hatchback, LH SLR5000
Posted 05 January 2011 - 09:08 AM
A couple of years ago I was after a product that did the same thing so I sent an email to Troy Trepanier in the States. He is a custom car builder like Chip Foose and whenever I saw builds he had in progress either on TV or the net they were always in bare metal and clean. I got a reply from him and he said that they all use GIBBS. If it's good enough for Troy then it's good enough for me. I just need to find out if you can get it here in Aus.
Ruts
#11 _LEE_
_LEE_
Posted 05 January 2011 - 09:18 AM
Id look into using lanolyn (spelling?)
#12 _dirtbag_
_dirtbag_
Posted 05 January 2011 - 09:39 AM
Using any oil will create paint adhesion problems in the future.
#13 _SnotGobbler_
_SnotGobbler_
Posted 05 January 2011 - 09:54 AM
Ruts
you can buy Gibbs in Aus... read the oldholden thread.. an Aus supplier is mentioned in it somewhere there
