aussie/trimatic pattern to turbo pattern adapter?
Posted 03 November 2010 - 10:41 AM
original plan was to find an early trimatic pattern 308 and buy a donor car running a 5L then swap all the injected gear onto the old block so I could retain the supra box that its currently running.
My old man mentioned adapters last night, I know they make them for certain things,
but how good are they and do they make one to go from trimatic to turbo pattern?
what are the downfalls (obviously its going to move the box back in the tunnel??
Posted 03 November 2010 - 10:44 AM
You can buy an adapter for Holden to Chev pattern but i've never seen one used on a manual. Most people just get the right bellhousing. Otherwise you'll need a spacer behind the flywheel.
Posted 03 November 2010 - 11:13 AM
Im looking to get out of it without too much dicking around.
so it seems my original idea is the best then.
Thanks mate.
Posted 03 November 2010 - 02:10 PM
Note that if you use a Chev pattern engine and bellhousing to suit, it will work OK with HQ and HJ or late HZ and WB, but HX and early HZ are a hassle as the clutch mechanism mounts off the bellhousing to block bolts, and as these move with a Chev pattern bellhousing the clutch brackets no longer fit!
Posted 03 November 2010 - 03:03 PM
Posted 03 November 2010 - 03:57 PM
_LEE_
Posted 03 November 2010 - 07:55 PM
Decided to do it before bed. From my understanding you use a chev pattern flywheel and trimatic stall in all these aplications
Castlemain rod shop do an adapter kit for $365, you will have to modify the inspection plate though and it spaces the box back so tailshaft would have to be shortened. Also was told from several people that these are just trouble and you wont be happy with them.
http://www.rodshop.c...ns/ap/ap014.htm
Craig at Torque power does a Bellhousing to pair them up, from memory it was around the $650 mark. best bet is to ring him on 0417556201.
/www.torque-power.com.au/
[email protected]
Rodney from Wholesale Automatics does brand new Bell Housing assembly for $995 inc gst,
Wholesale Automatic Transmissions
Factory 1/58 Barry St
Bayswater
Victoria 3153
Phone: 03-97628004
Fax: 03-97628108
[email protected]
Joe at Transtyle modifies trimatic bellhousings so they will bolt up to both a trimatic block and turbo block for $385, a further $88 if you wish for him to supply the bell housing. I thought this was the best option but after typing the shop name into google i found forum after forum of bad feedback from this shop.
Factory 1, 65-67 Hallam Rd, Hallam, Victoria, Australia, 3803
Tel: +61 3 9702 3188
Fax: +61 3 9702 3187
Email: [email protected]
