Identifying this master cylinder
21 replies to this topic
#1 slar
slar
  • 498 posts
  • Name:AL
Posted 04 November 2010 - 08:23 PM
Hi, I have just purchased a VK commodore double diaphram booster for my upgrade and this booster came with a master cylinder not attached to the unit.
The master is a 1 inch cylinder with the square type reservoir it has PBR 1 cast on the top of it but has no numbers that I can match to any PBR parts list.
The only numbers are 21B4 stamped on the end and a poorly stamped C3 1, as well on the under side it has cast numbers 3011 right where the front brake line attaches.
I have looked up the PBR listing and can only find this type of 1 inch cylinder being used on WB holdens P7955 (disc, drum,) P7954 (disc,drum) P7953 (disc,disc ,disc drum)
and commodore BT1 police packs, P10037 4 wheel disc I presume.
The problem is the numbers stamped on the cylinder dont match anything and there is no P- - - - number anywhere.
I know its for a holden because my old torana flare nuts screw into it.
The other clue wich might help identify it is that it has a black plastic reservoir cap with the standard rubber surround like normal and GMH moulded onto it but all other commodore ones Ive seen have had a steel cap with rubber gasket.
So Im at a lose to know what it is. I would like to use it if possible as its in real good nick but Im worried it might be for 4 wheel disc and Im going to keep the rear drums on my project..
So Datto if your there could you help and what type of master would I need to run standard disc on the front of my LX and drums on the rear with out rear wheel lockup, as i said earlier Im using a commodore booster and i would like to get rid of the original proportioning valve.
Also do VB-VL rear drum cylinders fit Lx Toranas as these are 22mm on the commodore and 19mm on the torana, Im thinking bigger diameter cylinders would remove rear wheel lock up if I did use a 4 wheel disc master due to the extra volume of fluid needed to activate them.
Any way look forward to any responses
#2 slar
slar
  • 498 posts
  • Name:AL
Posted 04 November 2010 - 10:04 PM
Just a correction, I said earlier that my torana flare nuts screw into this master cylinder, well the small ones do but very losely and the large one doesnt so im guessing the master cylinder is metric which would make it a commodore unit and not a Wb.
#3 dattoman
Posted 05 November 2010 - 01:41 AM
WB and Commodore are both metric
The C3.1 means it has a crack pressure of 3.1 ... which means its not Commodore cause they are C225
So I'd say its WB drum brake rear
Either way the disc and drum WB cyl interchange
Larger rear cyls increase pressure to the brakes ... so you would be more likely to have rear lockup than with the 3/4
#4 _horze_
_horze_
Posted 27 February 2014 - 08:53 AM
Sorry to bring up an old thread. Ive been doing a little bit of research on the brake masters, but havnt found much info other than this thread. Im doing an early commodore and just purchased a 1 inch master for it. Dattoman, was wondering if you knew what C155 is for?
Just a question too. Is WB and commodore same master other than the crack presssure, as in does it bolt up the same and etc?
Thankyou in advance for the info and hello to all as its my first post
#5 dattoman
Posted 02 March 2014 - 12:54 PM
The digits after the C stamped on the end denote the crack pressure
So C155 would be 155kPa
Commodore is 225 though... might be a typo...lol
Same bolt pattern... just double check rod clearance from booster is set right
#6 _horze_
_horze_
Posted 06 March 2014 - 09:38 AM
Thankyou for the reply dattoman.
Im abit fishy of this master, cant find what car or combination of would of been off
ive taken a photo of the markings to see if its more information for yourself
#7 _horze_
_horze_
Posted 06 March 2014 - 09:45 AM
also i thought this photo would help aswel.. just so you can get a visual of the actual masterbrake%20master1.jpeg
#8 dattoman
Posted 06 March 2014 - 09:01 PM
Look inside the ports
Does the flare come back at you ?
Or is it a drill point seat ?
I'd say its a WB ute or van one
#9 _horze_
_horze_
Posted 07 March 2014 - 09:47 AM
you lost me on that one
Edited by horze, 07 March 2014 - 09:47 AM.
#10 dattoman
Posted 07 March 2014 - 11:19 AM
Photo of inside the fluid ports please
#11 _horze_
_horze_
Posted 11 March 2014 - 01:51 PM
Thankyou dattoman for your help here are the photos.
To me there is a slight flare in the resovior ports.. but not a great deale.JPGd.jpege.jpega.jpegb.jpegc.jpeg
Edited by horze, 11 March 2014 - 02:01 PM.
#12 dattoman
Posted 11 March 2014 - 08:15 PM
Wrong hole she cried
The outlet ports
#13 _horze_
_horze_
Posted 14 March 2014 - 09:17 AM
The outlet ports
hahahaha love it! lol
not sure if its me but the port closer to the back towards the booster looks slightly bigger, i havnt got my vernier here to check. The ports are defenetly flared. No idea what model that means tho.
#14 _horze_
_horze_
Posted 14 March 2014 - 09:24 AM
Also for some more info as the pictures arn't the clearest. The deepest point of the flare is the actual fluid hole in the centre, The thread around the hole is higher. Just so you can tell which way the flare is pointing..  Which i am thinking about it.. is quite wierd... i usually see flares going the other way..
#15 dattoman
Posted 14 March 2014 - 08:09 PM
Looks like WB ute or van (not 1 tonner)
#16 _horze_
_horze_
Posted 16 March 2014 - 09:01 AM
ok thanks dattoman. So checking the ports is the best way to tell diff between commodore or wb. Cause i had a look at my 15/16 one that came with car and flare style is quite different
#17 dattoman
Posted 16 March 2014 - 07:26 PM
Only car to have 15/16 was Commodore
So if is that then its def Commy
WB was the first with metric ports... and they were drill point seat
VB-VN were inverted flares... then they went back to drillpoint
#18 _horze_
_horze_
Posted 17 March 2014 - 08:25 AM
So the one i showed you in the picture is a drill point seat?
so vb - vn is inverted
and vp onwards is  drillpoint?
#19 dattoman
Posted 17 March 2014 - 08:31 AM
They changed in 92...  mid VP
#20 _horze_
_horze_
Posted 17 March 2014 - 01:35 PM
ok and the picture i showed u is a drill point seat?
#21 dattoman
Posted 17 March 2014 - 09:07 PM
yup
#22 _horze_
_horze_
Posted 18 March 2014 - 08:47 AM
Thankyou for your help and information. You learn something every day:D
