where do vacuum hose's go on holley 600
7 replies to this topic
#1 _lostinspace_
_lostinspace_
Posted 07 November 2010 - 08:15 PM
Hi All
I'm not sure where the vacuum hose's go from my dizzy and gear box (Auto 3 speed). Carby is a 600 Holley.
Also where do the Canister hose's go to.
There is a small tube that comes out just behind the from bowl and a vacuum hose that comes out of the manifold but there is more than 2 things to be connected.
I have a picture if this helps
Attached File  car.jpg   101.93K   8 downloads
Thanks Nick
#2 TerrA LX
Posted 07 November 2010 - 09:16 PM
Gearbox goes to the t piece for the brake booster and dizzy goes to the front drivers side of the carby just behind the front fuel bowl.
What year model is your car, I thought there was no canister for your car.
#3 _lostinspace_
_lostinspace_
Posted 08 November 2010 - 07:30 PM
Thanks Terry
Need to double check on these thing sometimes I took some picture before pulling it all apart but still some things are not visable in the photos
It dose need a canister it didn't have one when you saw it cause I cut out the bracket and have a vs one under the front rail.
Can it be connected with the 600 Holley carby I have?
#4 TerrA LX
Posted 08 November 2010 - 08:06 PM
Yeah there should be a fitting in the base at the rear of the carby.
#5 _lostinspace_
_lostinspace_
Posted 11 November 2010 - 09:13 PM
#6 _lostinspace_
_lostinspace_
Posted 11 November 2010 - 09:26 PM
oops hit the wrong button.
There is a fitting at the front is this for the canister?
Attached File  IMG_4965.JPG   105.18K   5 downloads
It has a stop on it at the moment.
#7 _TorYoda_
_TorYoda_
Posted 11 November 2010 - 11:27 PM
Yes, the fitting at the front is for the canister, Vacuum line from dizzy to end of front metering block, gearbox kickdown direct to manifold plenum. Sometimes connecting the gearbox to the brake vacuum line cas cause erratic shifts.
#8 _lostinspace_
_lostinspace_
Posted 12 November 2010 - 09:33 PM
Thanks for that Guys
You have been very helpful.
