Alternator not charging
Posted 15 November 2010 - 01:31 PM
Havent been on here for a while...ages actually but have a silly question to ask.
Got an LX hatchback that i've been buidling the last few years, and have got a problem where the alternator is not charging.
Now, it's got a 400 chev with an 130amp MSD alternator (one-wire). Does the light brown wire trigger the alternator to start charging the system?.
The alternator came with a 4 pin plug also, which lists the following :
Switched 12V
Warning light
something else
Tacho
From memory, I don't think the one wire alternators need 12v ignition..?????
Any help is much appreciated.
Posted 15 November 2010 - 02:10 PM
G'day all,
Switched 12V
Warning light
something else
Tacho
G/day Noshead
So they give you a 4 pin wiring plug but the alternator only has one wiring connector not four, is that correct???
AFAIK the brown wire is your warning light wire. It appears that with some brands of aftermarket alternators you have to feed a 12v switched (from ignition switch) power source to them to boot them to start charging. I have no idea why the wiring instructions recommends connecting your tachometer to the alternator.
Dave.
_nemo355v8_
Posted 15 November 2010 - 06:01 PM
For a one wire alternator it sure does have a lot of wires, LOL
_fryzem_
Posted 15 November 2010 - 08:16 PM
cheers james
switched on auto elecs. 0407311946
Posted 16 November 2010 - 07:08 AM
Fryzem, I might give you a call if it's ok.
I'll post up some pics of the build in the next few days...if i ever get it going..!!
