cam gear squirter
8 replies to this topic
#1 _wknd warrior_
_wknd warrior_
Posted 14 December 2010 - 10:03 AM
has anyone had any problem with the standard cam gear squirter in high revving holden 6?
im in the process of building a fairly tough 202 for speedway and i have heard of guys using brake line and running the squirter from the under side of the gears so the oil doesnt get thrown off so quickly.
is this a mod that should be done or will the standard unit suffice?
cheers, ryan
#2 biga064
biga064
  • 196 posts
  • Name:Adam
  • Car:EH Holden
Posted 21 December 2010 - 03:43 PM
cheers, ryan
Hi Ryan , i know of several guys who race speedway or cuircut and some use standard squirter, some block the hole up all together . Theres probably enough oil that gets thrown around to keep it all lubricated thats why they block them off. Cheers Adam
#3 Com_VC
Com_VC
  • 411 posts
Posted 21 December 2010 - 07:30 PM
If it does get blocked off, do you think there would be an issue with too much oil going to the top end?
Anyone ever heard of the squirter poping out before, as it's just a pressed in fit?
I'm going to drill and tap the oil gallery and fit a plug there as I have heard about the welsh plug poping out before.
#4 warrenm
warrenm
  • 2,118 posts
  • Car:1972 LJ Torana
Posted 22 December 2010 - 07:29 AM
I have heard of them being pushed out , but usually when heavy oil, high oil pressure & giving the engine a rev when the oil is cold. I always drill & tap the gallery end to take a plug & make a screw in squirter for the gears with a smaller outlet than std.
#5 Com_VC
Com_VC
  • 411 posts
Posted 22 December 2010 - 03:24 PM
Do you happen to have a pic warrenm?
#6 warrenm
warrenm
  • 2,118 posts
Posted 23 December 2010 - 07:52 AM
Here's a couple of pics of a cam gear squirter from an engine I built some years ago.You can also see the gallery plug in the 1st pic, instead of the std welsh plug type.
Edited by warrenm, 23 December 2010 - 07:56 AM.
#7 warrenm
warrenm
  • 2,118 posts
Posted 23 December 2010 - 08:44 AM
The bolt size is 3/8" UNC. This squirter has a std orifice size of 1/16".
#8 turbotrana
turbotrana
  • 155 posts
Posted 24 December 2010 - 02:00 AM
I made a squirter for the plug just above the cam (main gallery)to squirt onto the thrust face of the cam gear and thrust plate as I always had wear at this point. I use standard gear squirter as my max oil pressure does not go past 45 psi with all the extra oiling I have in my 202
#9 _wknd warrior_
_wknd warrior_
Posted 26 December 2010 - 09:50 AM
thanks for the replies guys.. looking at my block it has had the std squirter removed and blocked and the welsh plug has been replaced with a plug the same as in warrenm photos.
i was also looking at my cam bearings and they have been turned so that the std oil holes dont align up? but opposite the std holes there tiny holes in the bearings that align with holes to the mains.. is this standard?
