Biggest tyres for LX sedan
_Terrible One_
Posted 18 December 2010 - 08:50 AM
Whats the biggest you guys have run? Will I get a 255/40R17 under the back and 235/45R17 under there with the correct offset and no rubbing?
_Bart15_
Posted 19 December 2010 - 03:08 PM
_cruiza_
Posted 19 December 2010 - 03:19 PM
Posted 20 December 2010 - 12:18 PM
205/60/15 on front with space to spare.
_Terrible One_
Posted 20 December 2010 - 05:39 PM
If I can even squeeze 225's up front that would be awesome but I'll see how far my luck goes...
_freddy_
Posted 01 March 2011 - 09:41 PM
im looking at usein convos 15x7 1/2 in torry pattern with a 5in back space
or convos in a 15x6 with a 3 3/8th backspace on the front of my unflared uc with none or 1in lower in front.
iv searched and i believe that if i use a convo 15x7 1/2 with a backspace of 5in i can use a 225-60-15 or 235-60-15 on the rear would this be correct?
thanks Matt.
Posted 02 March 2011 - 07:01 AM
If you go much over 600 diameter you may find the front tyre grabbing the bottom front wheel arch.
205/50 15 series tyres brings the diametre within under 6mm of standard.
I would be borrowing some wheels before laying down hard earned cash.
Edited by TerrA LX, 02 March 2011 - 07:03 AM.
_freddy_
Posted 02 March 2011 - 11:21 AM
5" backspace on the front sounds like it may be hitting things, 4" is closer to the mark but runs a 7" rim out to the guard edge.
o ok thanks mate didn't realize that 5in back space on front may hit things i may just get the 6in with a 3 3/8th back space convo pros as i don't want to change my stud pattern and i like the convos
and ill put 205-50-15 on.
thanks .
Posted 02 March 2011 - 11:34 AM
_uctorry_
Posted 02 March 2011 - 12:42 PM
255x 50x 15 on that back
225x50x15 on the front max on the front and lips rolled but still sometimes rub on a bad bump
hope that helps
uc torana by the way
_freddy_
Posted 02 March 2011 - 04:04 PM
torry stud pattern torry offset
hope that helps
any chance that you could post up a pic or two?
thanks matt
