V8 fly wheel machining
7 replies to this topic
#1 _1ARC_
_1ARC_
Posted 19 January 2011 - 02:25 PM
I am seeking recommendations or experiences that you may have on where to go or not to go to have a V8 fly wheel machined in the Perth area.
#2 dattoman
Posted 19 January 2011 - 04:51 PM
Its an easy flat flywheel
We can do it here
Unless your trying to lighten it
#3 _Viper_
_Viper_
Posted 19 January 2011 - 08:08 PM
Thread steal, Where is "here" ? can you also order in exedy or xtreme clutches from "here"
#4 _Quagmire_
_Quagmire_
Posted 19 January 2011 - 08:34 PM
i know
but i'm sworn to secerctry :innocent:
#5 dattoman
Posted 19 January 2011 - 09:46 PM
I'm around the corner from there
And yes to both parts of your question
#6 _1ARC_
_1ARC_
Posted 20 January 2011 - 11:29 AM
We can do it here
Hi Neil, I have examined the flywheel and i have discovered that there are several dodgy teeth. I think I will need to buy a new flywheel. Also I need to buy clutch plate and pressure plate kit. What is exedy or xtreme clutches? Are they a over kill for standard road applications. If so what would you recommend?
Cheers mate
#7 dattoman
Posted 20 January 2011 - 11:47 AM
They would be abit overkill for what your using the car for
I'd personally suggest a standard organic kit by Exedy
As for flywheel... I'd buy a new yella terra (steel) or extreme (CroMo)
Can work out some prices for you
Just need to know what bellhousing/fork your using... cable or rat trap.. push or pull
#8 _1ARC_
_1ARC_
Posted 20 January 2011 - 05:00 PM
Thanks Neil, I am going to use the standard clutch configuration for the Torana (V8 rat trap), i e., push type. Thanks mate.
