Can any one tell me where the bonnet release cable goes on an LX? I can�t seem to find any bracket/hole for the handle to be mounted.
If any one has some pictures could you post them here please.
Cheers Paul.
Bonnet release cable
its Paul
, Jan 28 2011 05:38 PM
6 replies to this topic
Posted 28 January 2011 - 05:38 PM
Posted 28 January 2011 - 07:30 PM
under the dash right next to the drivers door
Posted 28 January 2011 - 07:46 PM
Thanks for that FastEH I should have explained myself better, there�s nothing to mount it there, its been a while since I removed the cable but cant seem to find where the cable was mounted.
_Viper_
Posted 28 January 2011 - 08:00 PM
There is a little bracket that bolts to the bottom of the dash, ya probly missing this. Ill grab a pic tommorow if I remember
Posted 28 January 2011 - 08:01 PM
I think there should be a little bracket with two screws or bolts holding it into the lower part of the dash frame. Simple bracket with a 90deg bend in it, and the cable flange sits in that 'leg' that hangs down from the bend.
Posted 28 January 2011 - 10:06 PM
Thanks for that Clint & Heath, thanks in advance Clint for the photo.
Posted 29 January 2011 - 01:31 PM
Thanks for the photo Josh, went to the local wreckers & picked up this bracket (looks a little bent, big hammer will fix it) as well as one set of high low horns (high's not working yet) & horn relay for 20 bills, bit of a win for once.
