shudder on take off
_WILDWOGZ_
Posted 30 January 2011 - 08:09 PM
My torry (LH, m20, 173) has developed the strangest problem of a shudder when taking off from dead stop. Taking off as I would normally it does it everytime, but if I give it more revs the problem is very hard to detect. I think the car needs a tune as it was pinging in 4th, but can the cause of this shuddering be just because of a simple tune up?
any suggestions would be great because the car seems to drive fine, just that nasty take off giving the passengers (and the people around me at the lights) a bit of a scare ahaha
Posted 30 January 2011 - 08:40 PM
might be something else but on your car
Posted 30 January 2011 - 08:50 PM
_robslxhatch_
Posted 30 January 2011 - 08:59 PM
Posted 30 January 2011 - 09:34 PM
Posted 30 January 2011 - 09:38 PM
I have just gone thru the same thing mine was clutch was stuffed and flywheel needed machining
+1
Check the condition of your engine and gearbox mounts, replace them if they are doubtful but most likely your clutch and/or pressure plate is stuffed.
It is possible that the clutch facings are contaminated with grease or gearbox oil from a leaking clutch gear oil seal.
Either way I'm betting you'll be up for a new clutch.
_2ELCS_
Posted 30 January 2011 - 09:49 PM
_WILDWOGZ_
Posted 30 January 2011 - 10:09 PM
thanks for the help
Posted 30 January 2011 - 10:53 PM
_WILDWOGZ_
Posted 30 January 2011 - 11:01 PM
When the clutch plate was replaced, was a new pressure plate installed too? And did someone inspect the condition of the flywheel => was it machined if necessary? Normally it isn't so much a problem with the clutch plate itself, rather that the friction surface on the flywheel is no longer true & flat, so the clutch 'skips' across it.
When the clutch was done (my uncle did it) we looked at the old flywheel and the pressure plate, both were replaced as the old one had basically a 2mm deep cut into it from the old clutch plates pads wearing out so much that the rivets holding them in started acting as the clutch. (caused a shit load of slipping). So I purchased a clutch kit aswell as a used flywheel
_Quagmire_
Posted 30 January 2011 - 11:14 PM
if your under there checking the mounts you may as well
Edited by Quagmire, 30 January 2011 - 11:16 PM.
Posted 31 January 2011 - 12:37 AM
Posted 31 January 2011 - 12:55 AM
Posted 31 January 2011 - 01:06 AM
hmm I'm veering towards it being the engine and tranny mounts as the clutch wasn't replaced that long ago at all(under 6 months) . There would still be plenty of meat on the clutch itself, not too sure about the pressure plate though. Ahh guess I will have to check those mounts next time I go for a drive. Cant imagine this being an inexpensive fix ahahah
thanks for the help
You won't be driving the car to check the engine and gearbox mounts. New mounts won't cost a fortune.
This shudder wasn't evident immediately after replacing the clutch was it? Rather it has developed and gotten worse over time?
The shudder is also bad in reverse gear?
_nicko61_
Posted 31 January 2011 - 07:53 AM
When replacing a clutch that is completely stuffed you should ALWAYS machine flywheel so everything is nice and new,and never use a grinder or sander(worse still is the hi speed flex sander on a die grinder) very popular idea it seems when doing clutches ,end result is never flat and always ALWAYS leave tiny gouges and grooves which will damage your clutch plate very quickly,
"OH" did i say ALWAYS leaves gouges,"
Its amazing how many people will spend $200and up to $1000 on a new clutch kit yet baulk at $50 for their Flywheel machining,
With hot engines id advise anyone to also use ARP or similar Flywheel bolts(only cost about $25 a set, with locktight on thread,Cheap Insurance.
Edited by nicko61, 31 January 2011 - 07:59 AM.
_Yella SLuR_
Posted 02 February 2011 - 08:30 PM
+1 - Did you use new flywheel bolts? You shouldn't reuse flywheel bolts.or the flywheel is coming loose
Posted 02 February 2011 - 10:01 PM
also unlikely that they would come loose in his situation.
new clutch & machine flywheel.
_Quagmire_
Posted 02 February 2011 - 10:42 PM
(and most of that is visual/touchy feely)
you sure it's not the diff on it's way out?
i had a ve val with a REALLY FROCKED diff that did the same thing
_WILDWOGZ_
Posted 06 February 2011 - 10:24 PM
Forgot to add, the engine mounts were fine aswell
Edited by WILDWOGZ, 06 February 2011 - 10:25 PM.
_Quagmire_
Posted 06 February 2011 - 11:03 PM
#21
_robslxhatch_
Posted 07 February 2011 - 06:16 AM
