Fish Oiling
_Sneaky SLR_
Posted 08 February 2011 - 07:28 AM
This may sound like a dumb question but at what point in your project should you apply fish oil to the car ?
I have heard a few diff things so i though i would put it out there.
_Sneaky SLR_
Posted 08 February 2011 - 07:58 AM
_CraigA_
Posted 08 February 2011 - 08:29 AM
Just clean it down as much as possible where it runs out of the cavity's as once dry it can be a little hard to remove. Not impossible, just hard work.
Posted 08 February 2011 - 10:48 AM
A rag soaked in fishoil can spontaneously combust so care should be taken in disposing of any rags used.
Spontaneously Combustible Material
_nial8r_
Posted 08 February 2011 - 02:14 PM
Posted 08 February 2011 - 05:39 PM
Cavity wax is the way of the future.
I use Tectyl 506.
To reply to the OP's question, after paint before assembly.
_Quagmire_
Posted 08 February 2011 - 07:56 PM
just leave some clean rags under any drain holes for up to a week
and cleanup any leakage with metho/kero soaked on a rag asap
AND DON'T GET IT IN THE WINDOW RUNNERS
that's a bitch to clean up lol
Edited by Quagmire, 08 February 2011 - 07:57 PM.
Posted 09 February 2011 - 11:39 AM
I am going to use a product called LPS Hardcoate corrosion inhibitor. Available through QEA Australia.
The application gun i have pruchased through Evic Paints, product no SGST01030.
_uctorry_
Posted 09 February 2011 - 01:28 PM
i am wondering which is best or is it a personal preferrence
Posted 09 February 2011 - 05:37 PM
Also believe it was the original Endrust, but may be wrong.
Posted 09 February 2011 - 07:07 PM
As for fish oil, Iam old school, so, mix the fish oil with 50/50% INOX or WD40. This does several things. It makes the oil go further and It reduces the smell a little.
But more inportant is that it (due to the INOX or WD) pulls the fish oil into all of the seems, capiliary action, due to the viscosity of the fish oil is increased. Also fish oil hardens (skins over) and if you apply fish oil again (say in a couple of years) it will not seep into the seems, but just sits on top, not doing much at all. With the 50/50 mix, the INOX/WD will soften the old stuff and will then again seep into the joints.
Try it without INOX/WD and with, you will see the difference and be sold on the 50/50 mix.
I hope this helps.
Steve
Posted 09 February 2011 - 07:12 PM
_CraigA_
Posted 09 February 2011 - 07:40 PM
After 8 years no repairs have resurfaced except a small bubble where the rear quarter meets the rear wheel arch. Somewhere you would never get any product no matter the viscosity.
Each to their own, time will be the best test.
Posted 09 February 2011 - 07:51 PM
_CraigA_
Posted 09 February 2011 - 07:56 PM
Not fun.
Posted 09 February 2011 - 10:24 PM
_Kush_
Posted 10 February 2011 - 07:54 AM
I did a test with it on a piece of 1.2mm plate. I sprayed half of the piece in wax and left it out in the open for a few days.
Well, the wet season hit and after about 3 weeks I remembered that I left that piece out in the back yard. So I wandered out to have a look, the waxy side looked as new as when I first applied it. I cover everything in it now
Posted 10 February 2011 - 12:28 PM
_Quagmire_
Posted 10 February 2011 - 12:59 PM
and we never used fish oil or any sort of cocktail
just wax
mmmm
i think that says it all
#21
Posted 10 February 2011 - 01:39 PM
_Quagmire_
Posted 10 February 2011 - 02:55 PM
#23
_Sneaky SLR_
Posted 11 February 2011 - 06:32 AM
long island iced teas are the only cocktails i like lol
Yeah they are rather good hits me a little hard the next day but lol
So could you apply this wax before paint?
#24
_Kush_
Posted 11 February 2011 - 07:46 AM
#25
_Quagmire_
Posted 11 February 2011 - 11:49 AM
No. After paint
YEP
and don't have it near panels while you are painting
it can react and screw your paint job
make sure you have no silly cone products hanging around too
you can thin it down to get it to apply better
not sure if we ever did at work but
as it was hooked up to a 20 odd litre drum and wierd spay gun
when i did it
Edited by Quagmire, 11 February 2011 - 11:53 AM.
