XU-1 fan spacer
9 replies to this topic
#1 _SRC63_
_SRC63_
Posted 15 February 2011 - 12:27 PM
Can anyone tell me how long the spacer is that goes between the water pump pulley and the cooling fan blade on a '72 XU-1?
I haven't got one and need to know so I can buy the correct length.
#2 Bazza
Bazza
    ǝɹnʇxıɟ ɯnɹoɟ
  • 4,295 posts
  • Car:ɐuɐɹoʇ
Posted 15 February 2011 - 12:43 PM
Hi
No spacer required. The sequence is - water pump flange > pulley > fan blade > bolts.
Bazza
#3 _SRC63_
_SRC63_
Posted 15 February 2011 - 03:08 PM
Hi
Bazza
mmmmmm.....
I'm sure the fan didn't fit straight on to the pulley I have, which are both off an LH. I'll have another look when I get home.
This also means the fan will probably foul the 308 balancer I'm using that's been adapted to fit a 202!
#4 Bazza
Bazza
    ǝɹnʇxıɟ ɯnɹoɟ
  • 4,295 posts
  • Car:ɐuɐɹoʇ
Posted 15 February 2011 - 03:18 PM
Hi
The LH used a spacer - LJ/LC Torana 6 cylinders didn't.
Bazza
#5 _BATHURST-32D_
_BATHURST-32D_
Posted 15 February 2011 - 03:34 PM
the lj water pump is diffrent to the lc one mate, and that is where your problem will lay.
cheers gong
#6 Bazza
Bazza
    ǝɹnʇxıɟ ɯnɹoɟ
  • 4,295 posts
  • Car:ɐuɐɹoʇ
Posted 15 February 2011 - 03:46 PM
cheers gong
But neither type used a spacer
Bazza
#7 _BATHURST-32D_
_BATHURST-32D_
Posted 15 February 2011 - 04:56 PM
sorry yeah that is correct bazza.
cheers gong
#8 _SRC63_
_SRC63_
Posted 16 February 2011 - 12:57 PM
My bad.
The locating dowel on the water pump doesn't protrude enough for the fan to fit over it, just the pulley, so I assumed there was a spacer.
I guess the bolts ensure the fan is centered.
#9 _LC870_
_LC870_
Posted 16 February 2011 - 04:47 PM
My bad.
There are two types of water pumps with the large bolt pattern .
There is a long shaft and a short shaft pump .
You must have a short shaft pump as the centre hole in the fan blade must fit over the shaft of the water pump.
LC870
#10 _SRC63_
_SRC63_
Posted 26 February 2011 - 10:15 AM
OK, so now I have the correct water pump, but there's another problem.
The motor I bought came with 2 harmonic balancers, one standard and one from a 308 that's been modified to fit a 202. The crank has even been machined to take the bolt for the 308 balancer.
When I fit the 308 balancer the fan hits it and the counter-weight is so big that if I was to trim the blade I'd lose all of the bit that actually pushs the air.
So now I have a few more questions:
How much space is there between the pulley and the radiator?
Can I use a spacer or should I just go for electric thermo fans instead?
Or should I forget about the weighted balancer and just use the standard one? I'm not sure how much benefit you get from these things.
Any help would be appreciated.
