commodore K frames to suit v8
8 replies to this topic
#1 GML-31
Posted 26 February 2011 - 10:42 AM
anyone know if a VX k frame is the same as a VK
#2 Neils LX
Neils LX
  • 2,074 posts
  • Name:a
Posted 26 February 2011 - 01:05 PM
Are you using a V6 or V8 k frame. You can get a VN-VS k frame to fit but not sure on VX.
#3 _LH SLR 3300_
_LH SLR 3300_
Posted 26 February 2011 - 02:07 PM
Completely different. VB-VK are more or less the same apart from minor differences between manual & power steer, VL-VS are different yet again due to steering rack mounts & different engine mounts for 6cyl & V8, but are interchangeable ie a VL 6cyl K-frame can be used in a VR to fit an RB Nissan engine. VT-VZ K-frames will not fit in any first or second generation Commies.
#4 GML-31
Posted 26 February 2011 - 02:39 PM
after a v8 kframe for a vk and was told a VN-VR one would fit but was unsure on this
#5 Neils LX
Neils LX
  • 2,074 posts
  • Name:a
Posted 26 February 2011 - 02:46 PM
VK V8 k frames would still be dime a dozen? iv got a VH one if your realy stuck but im sure they should be easy to get. Where bouts are you?
#6 _LH SLR 3300_
_LH SLR 3300_
Posted 26 February 2011 - 03:05 PM
Any k-frame from VB-VS is interchangable between the models, it's the steering racks that are different. Example, a VN-VS k-frame will bolt into a VH but the VN-VS tie rod lengths are different, VR tie-rod lengths are different to VN & so on.
#7 _evil UC hatch_
_evil UC hatch_
Posted 26 February 2011 - 03:08 PM
the early k frmaes are the same between 6 and 8 Kev, the reccomendation for using a VN-VS V8 k frame is so you can utilise the VN-VP power steering rack as they are more compact than the earlier steering rack yet same width, (VR-VS racks are wider) allowing better clearance for extractors. the only difference between the earlier and later V8 k-frames is the little brackets that the rack bolt onto. V6 ones are very different.
#8 GML-31
Posted 26 February 2011 - 05:48 PM
ok great bought a VK today and want to throw a senator injected motor and box in it I have been tripping over
#9 _Quagmire_
_Quagmire_
Posted 26 February 2011 - 07:08 PM
the vn racks have a different input" spine to the vp's as well
just one to watch if you use the colum off, one and the rack off another
