Speco gauges
21 replies to this topic
#1 _Dan355_
_Dan355_
Posted 26 March 2011 - 08:12 AM
As the title says are speco gauges any good, or what do you recommend.
#2 dattoman
  • 16,488 posts
Posted 26 March 2011 - 12:09 PM
For what application Dan ?
VDO are good too
#3 Toranamat69
Toranamat69
    Forum R&D Officer
  • 2,117 posts
Posted 26 March 2011 - 12:20 PM
I originally had specos for mine when I was building it many years ago and had all sorts of trouble with them not reading accurately. From memory, they were very low impedance range on them and long cable lengths seemed to affect their accuracy. I changed to VDO and have no issues and they are a better quality guage that look better in my view. You will pay more for VDO's though.
I was using all electronic gauges to, not mechanical. Can't comment on their mechanical ones.
I ended up giving mine away to a mate and they are probably still sitting in his cupboard to this day I'll bet.
#4 _UCV80_
_UCV80_
Posted 26 March 2011 - 12:49 PM
You get what you pay for, but all my Speco gauges are all good, i have volts, water temp and tacho. Been using them for about 5 years.
#5 _Bomber Watson_
Posted 26 March 2011 - 06:16 PM
From the ones i have had i would say stay away.
You can buy Autometer guages from Summit for less than you can buy speco in AUS anyway so why bother???
Agreed with above VDO is very good.
#6 _Kush_
_Kush_
Posted 26 March 2011 - 07:53 PM
A mate of mine said that speco was an Australian made product??? Do we make crap things here or was my friend bullshiting me???
#7 Toranamat69
Toranamat69
    Forum R&D Officer
  • 2,117 posts
Posted 26 March 2011 - 08:09 PM
Speco is an Aussie company but their guages are made in Taiwan.
#8 _gmlj6_
_gmlj6_
Posted 26 March 2011 - 08:34 PM
i have a speco fuel pressure gauge and it fluctuates wildly. and i know its not my reg
#9 MRLXSS
  • 12,415 posts
Posted 26 March 2011 - 10:09 PM
I've had Speco guages, and never had an issue with them.... But I do think that Autometer ones look better and as DJ said, you can get them cheaper direct from the States!
#10 rodomo
  • 18,050 posts
Posted 27 March 2011 - 12:09 AM
The name Speco-(Thomas) dates back a million years and their stuff was originally made here along with heaps of other "old skool" hot rod bits like floorshifts for local column 3 speeds, solid lifter caps for hydraulic lifters, carby adapters :blahblahblah: :blahblahblah: :blahblahblah:
Now they're just using the name.
http://www.speco.com.au/
A link from that page:
http://www.speco.com.au/racing.html
Brian Sampson competed at Bathurst and won with Brocky in 1975. The story goes he only did a handfull of laps and that was only because Brocky needed to take a dump. He had a performance store called Brian's Speed Shop here in Melbourne many moons ago.
That's where you went to get your hotrod bits because there was nothing much else around then.
Brian Sampson is my first wife's father's cousin........Though I never met him, my kids are famous....sorta...aren't they? :dontknow:
Edited by rodomo, 27 March 2011 - 12:23 AM.
#11 mitchg
mitchg
    The guy with the Torailer
  • 3,111 posts
  • Name:Mitch
Posted 27 March 2011 - 08:15 AM
I run Speco fuel, volt, oil pressure and water temp in mine. They work well and were easy to wire up but I plan on swapping them all out for VDO to match my speedo.
#12 _nicko61_
_nicko61_
Posted 27 March 2011 - 08:28 AM
i had a set of speco guages i brought in 2007 and installed in my car in 2008 and only 1 out of 3 worked,took them back to Autobarn and even though the guarantee had run out months earlier they replaced them,took home and i now had 2 out of 3 work so ripped them out and put a set of summit (USA)cheap gauges in, which worked fine.
will never buy Speco gauges again
#13 _Dan355_
_Dan355_
Posted 27 March 2011 - 09:48 AM
VDO are good too
The car will be used as a street car plus start doing hill climbs and then work my way up to targas, I see Mark has VDO in his.
#14 ReplicarSLR
ReplicarSLR
  • 518 posts
  • Car:Not anymore unfortunately
Posted 27 March 2011 - 11:42 AM
"Stack" is another good brand but not cheap
#15 _Dan355_
_Dan355_
Posted 27 March 2011 - 01:19 PM
Cheers for all the replys, I think I will stay away from them.
#16 _hutch_
_hutch_
Posted 27 March 2011 - 01:32 PM
Yup steer well clear of them,and another thing you can buy the mulit plugs to fit on the terminals on the VDO gauges, makes the job so much neater and easier to work on at a later date
#17 _Mint_
_Mint_
Posted 28 March 2011 - 08:28 PM
I work for REPCO an sell speco gauges regularly but they are acheap AUTOMETER copy, i put speco on my commodore an the oil gauge filled up with oil after a month(leaked internaly) stick with VDO or AUTOMETER although they are dearer!
#18 dattoman
  • 16,488 posts
Posted 01 April 2011 - 07:01 PM
Hey Dan
Check this out... your cashed up right ?
GPS speedo... no need to connect to gearbox
Full of fruit and customisable
They do other sexy gauges too
http://www.speedhut...._number-890.htm
Or these Autometer ones look hot (american muscle series)
http://www.autometer...gid=3906&sid=74
#19 _Dan355_
_Dan355_
Posted 01 April 2011 - 09:06 PM
Hey Neil, i am receiving some cash after my other property settles in about 4 weeks. The GPS looks ok I don't go for the autometer ones.
I tried giving you a call at work today but you had left early. I'll give you a call next week.
#20 dattoman
  • 16,488 posts
Posted 01 April 2011 - 10:12 PM
Left early = dead
I've been very ill this week
I saw you called the mobile too... just haven't been able to do much this week
I thought the Speedhut gauges looked ok
Add a tacho and your set... for the $ they looked pretty cool
#21 _Dan355_
_Dan355_
Posted 02 April 2011 - 01:57 PM
Yeah the speed hut ones are pretty cool. They match up to the vdos ok as well.
Yeah I tried your mobile to, I will give you call next week and drop in and see you and I will drop those rust repairs off as well.
#22 _brett_32i_
_brett_32i_
Posted 02 April 2011 - 06:44 PM
same here. fitted mine today and it just jumps around. thought it might be lifters needing adjusting causing vac flucuations, but checked the vac gauge (autometer) and it was stable. bugger. im sure the dude wont swap it either.
