LJ steering column lower bearing size?
22 replies to this topic
#1 _brendan_h_
_brendan_h_
Posted 02 April 2011 - 10:10 AM
Ive got a bit of place in the lower bearing in steering column on my LJ torana, ive managed to pull the old bearing/bush out. Does anyone know of a replacment bush or bearing part number?
thanks
#2 S pack
  • 15,542 posts
Posted 02 April 2011 - 02:28 PM
Hi Brendan
AFAIK nobody makes a replacement bush.
How bad is the wear, like how much slop do you reckon there is between the bush and the shaft??
Dave
#3 _brendan_h_
_brendan_h_
Posted 02 April 2011 - 02:58 PM
Hi Brendan
Dave
its faily floged out, 1mm or more i guessing?
if its the same shaft as the LX/LH toranas i can replace it with bearing 6205-2RS-1. this is a 1inch bore fitting on the shaft and a 52mm outershell.
#4 S pack
  • 15,542 posts
Posted 02 April 2011 - 03:01 PM
Hi Brendan
Dave
Nope, LJ steering shaft is not the same as LH - LX.
LC - LJ bush is .770" internal Dia, the OD is probably similar.
#5 rodomo
  • 18,001 posts
Posted 02 April 2011 - 03:03 PM
http://www.nachi.com...s_rsDG_open=214
#6 TerrA LX
Posted 02 April 2011 - 03:05 PM
Go to a bearing shop and ask for a case roller bearing with the same inner and outer diameter, a hose clamp should hold it or glue it in place with appropriate glue.
#7 dattoman
  • 16,473 posts
Posted 02 April 2011 - 03:16 PM
Or someone could turn that up for you in nylon easy
#8 _brendan_h_
_brendan_h_
Posted 02 April 2011 - 03:34 PM
thats the last resort
#9 S pack
  • 15,542 posts
Posted 02 April 2011 - 03:35 PM
A roller bearing would need to be less than .770" ID to be a snug fit on the steering shaft.
#10 _brendan_h_
_brendan_h_
Posted 02 April 2011 - 03:39 PM
.770 inch is 19.5mm
how much less are we talking? and i doubt you could even geta bearing in this size. will probably just have to get one made up. any special kid of nylon?
#11 Toranamat69
Toranamat69
    Forum R&D Officer
  • 2,117 posts
Posted 02 April 2011 - 03:44 PM
I would use acetal rather than nylon.
Harder and self lubricating but very nice to machine.
So the LC's don't use a roller bearing? just this plastic bush?
#12 _brendan_h_
_brendan_h_
Posted 02 April 2011 - 03:45 PM
there wouldnt be a problem using nylon though would there? what about brass, even aluminium?
cant imagin LC having a roller bearing and LJ have a bush.
anyone got a rought idea on cost to machine this up?
Edited by brendan_h, 02 April 2011 - 03:50 PM.
#13 S pack
  • 15,542 posts
Posted 02 April 2011 - 08:21 PM
LC and LJ use the same bush.
I'd stick with a plastic like nylon or the Acetal that Toranamat69 mentioned, if you consider having one made up.
As for price to make one, no idea really, maybe $100.00.Could be cheaper if you can drum up orders from other LC-LJ owners and get a batch made.
#14 _brendan_h_
_brendan_h_
Posted 02 April 2011 - 09:04 PM
Going to get one made up from nylone on monday. Anyone confirm the dimentions it needs to be
#15 S pack
  • 15,542 posts
Posted 02 April 2011 - 11:06 PM
G/day Brendan
Measured my NOS bush. (sorry not for sale).
OD = 2.050" (52MM give or take a mick hair) not including the flange.
ID = .770" (19.5mm as you calculated)
Measured a spare steering shaft.
OD of shaft where it runs in bush = .748" (allowing for a bit of wear may have originally been .750")
My calculation is that the factory tolerance between bush and shaft was .020"
Basically though if you do get one made just give them your old one to copy and have the hole in the centre machined to .770" dia.
I think using a self lubricating plastic would be a great advantage in extending the life of the new bush.
Dave.
#16 S pack
  • 15,542 posts
Posted 03 April 2011 - 11:09 AM
G/day Brendan
Try this mob in Sydney - All Plastics Engineering.
The Cast Oil Filled Nylon 6 sounds promising
http://www.allplasti...ial/castoil.htm
Dave
#17 _brendan_h_
_brendan_h_
Posted 10 April 2011 - 10:16 AM
i eneded up getting a bush machined up. not 100% on what plastic they used, but im going to say nylone as its creamy colour. got it made up for free so cant complain. play in steering is all gone now :)
#18 flygtr028
flygtr028
  • 51 posts
  • Car:1970 LC GTR Daytona Bronze
Posted 13 April 2011 - 03:52 PM
The closet bearing i can find is 6304
20mm ID
52mm OD
15mm width
#19 _BIGCAV_
_BIGCAV_
Posted 13 April 2011 - 05:19 PM
what is the difference between a column shift and floor shift bearing? are they interchangable?
#20 S pack
  • 15,542 posts
Posted 13 April 2011 - 06:00 PM
Hey Cavan
The lower column bearings are different for column shift and console shift. Basically the column shift bearing has to also accommodate the gearshift shift tube as well as the steering shaft.
I don't think they are interchangeable, but not really sure.
Dave.
#21 orangeLJ
  • 10,259 posts
Posted 21 November 2011 - 01:07 PM
Bringing up an old thread,
I believe the lower bush in my steering column has compeltely degraded, there is about 2cm movement either way (so 4cm in total) at the end of the column rod.
Pulling it out on the weekend, but would a bearing be the most practical method to solve the problem?
Im sure I could find one close enough to fit, bit of machining wouldnt be too painful.
#22 _hutch_
_hutch_
Posted 21 November 2011 - 06:01 PM
i converted my ex column shift to a floor shift,all i did was to cut off the section where the shift lever come out on the column and machined up a housing and fitted a nylon bush inside it
Phillip
#23 Toranamat69
Toranamat69
    Forum R&D Officer
  • 2,117 posts
Posted 11 February 2013 - 10:54 PM
You could use the same roller bearing as the LH/LX and just use a 3/4 to 1" adaptor like this http://www.smallpart...stension/all/1/
