So we decided to convert the car to Hydraulic clutch.... The stock 13B 3/4" Slave cylinder and a Wilwood 3/4" Master cylinder fitted it all bled it up and still super heavy :( remove the slave from the gearbox and it works perfect pushes in and out with ease.
So we thought maybe we had used the wrong throwout bearing or something else was wrong so pulled the motor/box out and separated and well I dont really know much about clutches but dont know what to look for... But noticed the fingers on the pressure plate are like flat (vertical) and I think there supposed to be sticking out towards the gearbox a little?
I had this problem once a couple of years ago on another Exedy gemini clutch and we had to put washers between the pressure plate and flywheel to the fingers were at the right angle otherwise there wasnt enough throw to get the clutch to dis-engage, But I dont remember it making the pedal extra hard?
Here's a couple of pics of the pressure plate as is... anyone got any ideas? can also see the wear marks on the fingers are a little bit back from the tips... are they supposed to be right on the end?
