Plastic Glue
10 replies to this topic
#1 _BCR42Y_
_BCR42Y_
Posted 28 April 2011 - 08:57 PM
Hi All,
Not 100% sure if this is in the right section, if not feel free to move.
I am looking for recommendations on a good strong readily available plastic glue to use on a dash, none of the components will be seen, but i require it to not only glue but add strength to the parts.
#2 S pack
  • 15,736 posts
Posted 28 April 2011 - 09:41 PM
Hi All,
I used some special plastic glue (Selleys' make it I think) on the VS dash fascia centre air vent mounting screw posts. Worked well on one post but the other one split again when I tightened the screw up.
I've always found welding the plastic with a soldering iron works better but in the case of the VS screw posts it wasn't feasible.
#3 FastEHHolden
FastEHHolden
    Steptoe
  • 5,114 posts
Posted 28 April 2011 - 09:43 PM
I use Araldite
#4 ls2lxhatch
  • 5,334 posts
Posted 28 April 2011 - 10:05 PM
ZAP Superglue (Cyanoacrylates) used with ZAP Zip Kicker is good. ZAP is available in a range of viscosities and a Gel. The thin and super thin are good for getting into cracks. You will find ZAP in hobby shops. Experiment with gluing some other plastics first.
Permatex® PermaPoxy™ 5 Minute Plastic Weld is similar to araldite and can be used to build up the area.
Edited by ls2lxhatch, 28 April 2011 - 10:06 PM.
#5 _Gunmetal LH_
_Gunmetal LH_
Posted 28 April 2011 - 10:27 PM
Loctite 401 is a cyanoacrylate/superglue. Works killer for many things. Keep it in the fridge and it will last until it runs out.
It's very strong but brittle.
The other glue I use is a 2 part epoxy from the local hobby shop. It's a "15 minute" glue. Pretty runny for around 5 mins before it starts to cure and will be hard-as-a-rock in 20 mins.
Depending on what it is- I scratch the crap out of it with a hacksaw blade or similar so the glue has something to hold, then I tack it in place with the loctite and build it up with the 15-min stuff.
#6 _purpleLC_
_purpleLC_
Posted 28 April 2011 - 10:54 PM
Go to a REPCO store and buy some "Q Bond" (q bond)
It comes with a glue and plastic and metal filler powders.
You sprinkle a little bit of powder on a peice you want repaired, built up or strengthened, then put a drop of the glue on it
and it hardens up almost straight away.
I love the stuff.
#7 _honda400_
_honda400_
Posted 29 April 2011 - 06:49 AM
Q bond is the best stuff ever. I love it to.
#8 _LS1 Hatch_
_LS1 Hatch_
Posted 29 April 2011 - 07:29 AM
I have been using Zap for many years, it's really good stuff !
Also, Q-bond is awesome as well, used it with the filler powder on a number of things... :clappin:
#9 warrenm
warrenm
  • 2,119 posts
  • Car:1972 LJ Torana
Posted 29 April 2011 - 08:03 AM
Loctite 406 cyanoacrylate seems to work great with automotive plastics.
#10 _glenn l_
_glenn l_
Posted 29 April 2011 - 09:11 AM
cant go wrong with the q-bond, got me out of a lot of sh1t.
#11 rodomo
  • 18,044 posts
Posted 29 April 2011 - 05:53 PM
Hang on? Am I reading this right? Q bond? Something that actually works as advertised? :dontknow:
