filler over etch
5 replies to this topic
#1 _TUFF75LH355_
_TUFF75LH355_
Posted 28 April 2011 - 11:31 PM
After you get a panel in bare metal the next step is to etch to help against rust ..??? correct or not..?? also can you apply etch and use filler over the top ..??? ( paint will be acrylic ) ..?? cheers ben
#2 _robslxhatch_
_robslxhatch_
Posted 29 April 2011 - 07:20 AM
isn't all primer porous ?? allowing rust to form underneath?? i cringe every time is see a car in primer waiting to be painted and its out in the rain.I am sure its better than bare metal though!!
#3 _dirtbag_
_dirtbag_
Posted 29 April 2011 - 07:44 AM
I use 2 pac epoxy etch and do all filler work over the top. Not sure about acrylic etch though. Ask Bomber.
#4 Bathurst72
Bathurst72
  • 108 posts
Posted 29 April 2011 - 11:39 AM
Hi, NO to body filler over any cryl primer. Just rough it back up with the grinder before applying your body filler to a point where most of you etch has gone. Put primer/filler over your etch. Yes to spot putty over primer.
I hope this helps.
Steve
#5 _Quagmire_
_Quagmire_
Posted 29 April 2011 - 12:03 PM
I hope this helps.
Steve
2 pac etch is ok to use under acylic ........according to the man bomber :)
forget spot putty...it's useless
use a 2 pack fine filler like dolfin glaze
#6 _Bomber Watson_
Posted 29 April 2011 - 06:58 PM
First question, yes, but i hate acrylic etches.
Agreed with 2k fine filler.
I wouldent put bog over acrylic etch, chances are the bog will melt/frOck up the acrylic etch.
As said scuff it right back.
Edited by Bomber Watson, 29 April 2011 - 06:59 PM.
