lj xu1 upper control arm bump stops
Posted 07 May 2011 - 09:15 PM
_sunburst73-xu1_
Posted 07 May 2011 - 09:24 PM
Posted 07 May 2011 - 09:37 PM
If I'm reading your question right,it is normal for the upper bump stops the touch.
so it is normal to be compressed?
_TorYoda_
Posted 07 May 2011 - 09:40 PM
Posted 07 May 2011 - 10:23 PM
Once it is on the ground with the weight of the car and engine on the wheels there will be close to 2". It's recommnded to not fully tighten any of the suspension bush fasteners until it is on the ground with the parts in their 'neutral' position. This saves them from excessive twisting in the rubber that can shorten their life expectancy. Nolathane or similar do not suffer this problem but rubber ones will.
OK thank you
Posted 08 May 2011 - 07:02 AM
Rubber or Urethane (Nolathane), it doesn't matter. Don't tension the bush bolts up until the car is on level ground and at full kerb weight.
