mig gas pressure
17 replies to this topic
#1 _2wild4u_
_2wild4u_
Posted 12 May 2011 - 11:57 PM
hi, when welding body panels with a mig welder what should the gas pressure be on?
#2 Statler
  • 6,328 posts
Posted 13 May 2011 - 12:09 AM
Indoors or out doors?
Gauges & regulators offer only a guide. They aren't accurately calibrated.
General rule of thumb, around 12-15ltrs.
If there are black/brown sooty deposits in the HAZ [heat affected zone], then gradualy cut back on the gas flow until you find a happy medium.
Or... if you are a back yarder, when you pull the trigger, the nozzle should say psssshht.
#3 rodomo
  • 18,055 posts
Posted 13 May 2011 - 12:31 AM
And wind! What a difference THAT makes.
#4 _nial8r_
_nial8r_
Posted 13 May 2011 - 09:24 AM
my gauges say about 5ltrs/min and works well but like col said the gauges aren't accurately calibrated so just go off the sound of the gun when you press the trigger ( pppsssss ) and welding in the wind with a mig is just one big friggin nightmare and is almost impossable :surrenderwave: unless you do what i do and get the wife to stand there with a piece of ply wood :Buddy:
#5 Mort
Mort
  • 2,760 posts
  • Name:Mort
Posted 13 May 2011 - 09:53 AM
Too much baked beans Rob :lol: .
Sorry couldn't help myself :sofa:
#6 355LX
355LX
    Long Term Project
  • 611 posts
  • Car:LX hatch
Posted 14 May 2011 - 02:04 PM
I work with about 16-17ltrs/min and am ina car port.
Dave
#7 _2wild4u_
_2wild4u_
Posted 15 May 2011 - 09:46 PM
cheers for that
#8 FastEHHolden
FastEHHolden
    Steptoe
  • 5,114 posts
Posted 15 May 2011 - 10:39 PM
My welder's instruction book says 5 lt / min...i think i use a little more than that ...its hard to tell as my flow meter is on an angle
#9 _nzstato_
_nzstato_
Posted 16 May 2011 - 05:38 AM
I find 6-7 lt/min works well for me. Anymore and the weld is either too cold and when it heats up it blows it straight through
#10 LXM21
LXM21
  • 450 posts
Posted 16 May 2011 - 08:04 PM
Above has got little to do with gas flow. More like an amps/volts/wire feed issue.
Ideal gas flow 11-13lit/min
#11 _Holden89nut_
_Holden89nut_
Posted 07 June 2012 - 09:03 PM
Gas flow and mixture has a massive effect on heat input of the weld, gas flow will depend on size of the mig shroud and Amps and volts. This comes from a full qualified boilermaker with welding tickets and numerous fillet welds and full strength butts test to mag particle, ultra sonic, x ray and macro etc
For a medium size nozzle I would say 10 to 13 ltrs
#12 _shan620_
_shan620_
Posted 07 June 2012 - 11:39 PM
does the gas pressure change with the different thickness's of metal thats being welded?
#13 _Holden89nut_
_Holden89nut_
Posted 08 June 2012 - 07:02 AM
Not so much pressure but type, if using boc gas, use Argo shield light, if welding heavier steel like 10mm plus start looking into Argo shield universal
#14 Shtstr
Shtstr
    Formerly lcxu105
  • 1,810 posts
  • Name:Mmmmmmm
  • Car:lx hatchback lc gtr
Posted 08 June 2012 - 08:06 AM
do some test welds on some spare steel. if you get bubbles then turn the gas up more till it is all gone and thats where you should be. bubbles are porisity and thats no good.
#15 Ruts
Ruts
    How Fast!?
  • 1,118 posts
  • Car:Blown A9X replica, Black SS hatchback, LH SLR5000
Posted 08 June 2012 - 11:45 AM
How does it go again Col???
#16 Statler
  • 6,328 posts
Posted 08 June 2012 - 12:48 PM
I don't know m8, it's been a while. :)
#17 _turbotorrie_
_turbotorrie_
Posted 11 July 2012 - 09:20 PM
Every where I have worked we always ran 25lts/min with wire from .8 to 1.5 welding thin and thick steel
#18 _TorYoda_
_TorYoda_
Posted 18 July 2012 - 10:32 PM
I have always used the 5-6 l/minute as taught to me in Boilermaker school over 30 years ago. If it's windy outdoors more is sometimes needed. Anyone using more than 5l/minute indoors is wasting what we all know is an expensive consumable.
