Rust treatment
13 replies to this topic
#1 Indy Orange
Indy Orange
  • 2,968 posts
  • Name:Paul
Posted 06 July 2011 - 10:59 PM
,Hi everyone,need a bit of expert advise here,I recently had the rust cut from my doors on my HJ Holden which was good but i wanted to make sure it was,nt going to come back so i liberally sprayed the inside of my doors around the seems with ranex i think its phosphuric acid ,anyhow i did not neutralise this or wash the doors out because it was winter i figured they would never dry out .I ended up then spraying the inside of the doors with a mixture of fish oil and lanoline .My question is ,would this have neutralised the acid ?or should a clean the doors out to stop the possible activation ?,i was thinking washing out with diesel.I am i bit worried about this after forking out to have the rust done .Help much appreciated.Paul.
#2 71xu1
71xu1
    Dave
  • 1,276 posts
  • Car:LC GTR XU1
Posted 07 July 2011 - 03:47 PM
Thats a hard one but I d be neutralising the ranex with water and then reapplying the rustproofing.
#3 Indy Orange
Indy Orange
  • 2,968 posts
  • Name:Paul
Posted 07 July 2011 - 04:30 PM
What about if i flood with crc ? that should neutralise the acid and clean everything out?
#4 71xu1
71xu1
    Dave
  • 1,276 posts
  • Car:LC GTR XU1
Posted 07 July 2011 - 10:50 PM
Ever tried washing Fertan or exit rust off or any water based product off with paint thinners/solvents it doesn't work. My point water based product you will find you will have to use water to wash it off or neutralise it. But I suppose it can't hurt to try CRC at least your doors won't squeak.
#5 _Quagmire_
_Quagmire_
Posted 07 July 2011 - 11:16 PM
you have to remove the "fish oil etc" before you can neturalize the acid
as you have created a barrier
fyi cavity wax is way better than fish oil anyway hint hint :)
#6 ls2lxhatch
  • 5,335 posts
Posted 07 July 2011 - 11:27 PM
According to the instructions Ranex does not need to be neturalised.
Ranex Instructions
RUST CONVERSION
•Remove oil, grease, paint and loose scale
Apply Ranex & allow to dry completely in order to penetrate deep rust & to leave surface in a suitable condition for
painting with an oil based primer.
As Ranex chemically destroys rust it is not necessary to use rust inhibiting paints. Zinc
rich paints are not recommended.
•Apply Ranex to the rust effected areas only, wipe off any excess on surrounding metal or paintwork with a damp cloth.
-Note Ranex Rustbuster will convert the rust however it will not prevent it from re-occuring. Treated surfaces left
uncoated may experience further rusting.
Edited by ls2lxhatch, 07 July 2011 - 11:30 PM.
#7 _Quagmire_
_Quagmire_
Posted 08 July 2011 - 01:16 PM
he he knew i liked ranex for a reason
can you still get it at bunnings and malz/ supa crud
#8 kingsly
kingsly
  • 235 posts
Posted 08 July 2011 - 01:28 PM
still avail here in sa at bunnings and supa crud.. i love the stuff
#9 Indy Orange
Indy Orange
  • 2,968 posts
  • Name:Paul
Posted 08 July 2011 - 11:02 PM
I ended up using petrol to remove the fish oil and neutralise the acid seemed to work fine it left the inside of the doors dry and clean as the petrol evaporated ,have to make sure it does not come in contact with rubber seals though thanks for the advise guys .
#10 _Quagmire_
_Quagmire_
Posted 08 July 2011 - 11:16 PM
yeah went to bunnings ...and supa crap and malz today
only saw it at bunnings
#11 Indy Orange
Indy Orange
  • 2,968 posts
  • Name:Paul
Posted 09 July 2011 - 11:45 AM
Tighter men ,oh i mean Mitre 10 has it.
#12 christolx
christolx
  • 184 posts
  • Name:Chris
  • Car:1976 LX SL Coupe
Posted 10 November 2019 - 06:55 PM
Hey I know this is a super old thread. But I've just used Ranex on my fuel tank yesterday. Attempted to paint over it today, but the pain is just turning to goo, clumping up and peeling off...have I missed something? the site says theres no need to neutralise it? it's definitely dry, but I can't seem to paint over it :huh:
#13 claysummers
claysummers
  • 3,664 posts
  • Name:Clay
Posted 10 November 2019 - 10:43 PM
I wouldn’t paint straight over it. Rather buzz it off with wire brush at least. They say you can paint oil based enamel over it.
#14 claysummers
claysummers
  • 3,664 posts
  • Name:Clay
Posted 10 November 2019 - 10:49 PM
Just tried it on my Ute tray. I kind of like it as is but plan is to buzz with wire brush, scrub with floor prep, deoxidine and wax and grease then Epotec 2k etch.0e67606d3a389392545415f9540c31e3.jpg0bf78c66cf1213fefd327729ff7b4a41.jpg
Sent from my SM-A705YN using Tapatalk
