LH 2850 conversion to V8
_joshua626262_
Posted 14 July 2011 - 12:40 AM
I have just bought a 74 LH 4 door it is a 2850 and its a coloum manual. I want to do a V8 manual on the floor conversion. But I am tossing up between a injected V8 out of a VN/VT with the T5 or a V8 red motor with a T5?
I was wondering if anyone has done these conversions before and what problem would I expect to run into?
And what would be the cheaper option to go with?
Regards
Josh
Posted 14 July 2011 - 08:17 AM
you will need the
motor
a v8 alternator from a vn most likely
a torana v8 alternator bracket
v8 engine mounts
kings or torana v8 sump
extractors
v8 radiator and ya might aswell throw some au thermos in they work soo good
make sure you get a bosch hei dizzy from a blue motor
as for gearbox get a ford 6 box and a crs bell housing the ford box is shorter so it brings the shifter into line where they should be roughly
then you will need to get a tailshaft made up
Posted 14 July 2011 - 11:37 AM
Check some of the member's cars as both options have been done.
User name LH SLR3300 has done the 5l EFI so his build threads have a wealth of information.
Cheers,
Phillip
_nial8r_
Posted 14 July 2011 - 12:13 PM
_330OLX_
Posted 19 July 2011 - 08:17 PM
IMO i would go with the EFI set up,
I thought the same thing until I had a really good look at one on Sunday.
HOW THE HELL DO YOU CHANGE THE DISTRIBUTOR CAP ? THERE DOESN'T SEEM TO BE ENOUGH BLOODY ROOM TO DO IT WITHOUT REMOVING THE WHOLE ENGINE
_LH SLR 3300_
Posted 19 July 2011 - 08:54 PM
LH 2850 to EFI 5.0ltr.
LH 2850 to carby 5.0ltr
LH 3300 to EFI 355
I'm no expert & i'm certain there are more knowledgeable people you can speak to on this forum, but i did all these conversions myself with little to no help so feel free to PM about them if you like. Cheers Matt
Posted 20 July 2011 - 01:11 PM
how many pics have you got?
Did you want to run up a basic "How To...?" article for everyone?
When Josh does it he can grab extra pics to fill in the blanks
Grant..
_LH SLR 3300_
Posted 20 July 2011 - 06:07 PM
Posted 20 July 2011 - 06:29 PM
_LH SLR 3300_
Posted 20 July 2011 - 07:30 PM
_j.e.d._
Posted 21 July 2011 - 07:27 PM
Jase
_joshua626262_
Posted 27 July 2011 - 02:28 AM
I would be very interested to see more pics and a step by step "how to".
I am sure everyone would in my situation would appreciate it.
_nial8r_
Posted 27 July 2011 - 08:07 AM
_heapa_
Posted 29 November 2011 - 03:14 PM
_LH SLR 3300_
Posted 29 November 2011 - 06:00 PM
This tool will be invalueable for testing voltage, resistance & finding circuits. When looking at an EFI harness removed from a car, it can appear very daunting, however alot of the circuits will be made redundant when fitting to a Torana (A/C, heater fan etc) & once removed the harness ends up half the size. This is another invaluable tool i've used for doing the conversions on my cars.
It shows all of the circuits needed to run the EFI & also shows each numbered circuit on the two plugs that go into the ECU making it easy (combined with the multimeter) to determine which wires/circuits you need & which ones you don't.
For example, the two harness plugs that plug into the ECU have two circuit bars each marked A-B & C-D respectively. The main 12V sources to power up the ECU are marked on the plugs "C16" & "B1". Distributor input "B5" distributor earth "B3" etc. There are some things the manual won't show as it is a GMH service manual for VN Commodores, but it breaks down the EFI harness making it easier to splice it into the Torana harness. I've been pretty busy of late on my SL/R, which has prevented me from starting up a thread on how i did my conversions, plus the fact that my computer skills are limited, but you're more than welcome to PM me if you have any questions or you would like some copies of my wiring diagrams. Cheers Matt
_TheGatch_
Posted 08 May 2017 - 07:59 AM
