engine indentification
Posted 20 May 2006 - 08:14 PM
Posted 20 May 2006 - 08:35 PM
Posted 20 May 2006 - 09:25 PM
Posted 20 May 2006 - 09:33 PM
rgds
blown308
Location - Sydney
#5 _JBM_
Posted 20 May 2006 - 10:13 PM
James
Posted 20 May 2006 - 10:24 PM
Posted 20 May 2006 - 10:48 PM
Posted 20 May 2006 - 11:34 PM
#9 _JBM_
Posted 21 May 2006 - 12:13 PM
The reason I asked is some L34 blocks had an X above the 308 casting.What is the engine number prefix?
James
Your HT prefix is a stock 308.
If you can find the cast date on the block it may help as well.
On my VH 253 this is below the passenger side head at the front.
eg 18D2 is 18th April 1982 for a blue motor.
James
Posted 21 May 2006 - 06:51 PM
normally, it would be NT for a new block, but some of the later ones had R on the end instead.I saw an SS genuine everything the other day with a R stamped after the HT engine number... so Red does this mean replacement???
Posted 22 May 2006 - 01:03 PM
#12 _Herne_
Posted 22 May 2006 - 01:12 PM
Is it at all possible they had L34 style blocks left over that were not stamped at the time? and later put into other cars eg a Monaro. It would make sense for the X...I would not have thought that they made an exact number of blocks for the cars, to have some unstamped left over may be a possibility?I have seen a 308 with an X cast above the 308 on the side, it wasnt a L34 block though I think it was date coded for '72. I belive it came from a Monaro, now in my mates HZ.
Herne
Posted 22 May 2006 - 01:53 PM
if it was date coded 72, it's more likely to be one of the ones earmarked for the XU1 V8 project but stamped as an LH block, so prior to L34.Is it at all possible they had L34 style blocks left over that were not stamped at the time? and later put into other cars eg a Monaro. It would make sense for the X...I would not have thought that they made an exact number of blocks for the cars, to have some unstamped left over may be a possibility?I have seen a 308 with an X cast above the 308 on the side, it wasnt a L34 block though I think it was date coded for '72. I belive it came from a Monaro, now in my mates HZ.
Herne
#14 _Herne_
Posted 22 May 2006 - 01:59 PM
I still cant get my head around why some have an X and others do not, it would appear they were marked that way for a reason. Better blocks with more meat?
Herne
#15 _[2_FLY]_
Posted 22 May 2006 - 02:51 PM
#16
Posted 22 May 2006 - 05:17 PM
#17
Posted 22 May 2006 - 05:59 PM
just makes it easier to identify when the paqrts are on the shelf at the factory so they go in the right car. Blocks are not the only part to have such markingsSorry RedA9X, I meant any of the 308 blocks that carry an X from the factory 'cos the odd one seems to come up every now and then.
Herne
