LX 9 inch diff problem/noise
_slr5000.com.au_
Posted 21 July 2011 - 08:53 PM
I have a LX sedan with ford 9 inch with diff noise that i cant seem to fix it has had 3 different gear sets in it trying to ilimimate diff noise (gear noise)
i have had a reputable diff specialist do the job but still noisy.
has anyone had same problem if so possible fixes as im running out of ideas
Chris
Posted 21 July 2011 - 08:58 PM
_slr5000.com.au_
Posted 21 July 2011 - 09:16 PM
some gear sets (ratios) are noisy by design.
Posted 21 July 2011 - 09:19 PM
Lucky I was changing diff ratio because I wanted a different ratio, not to actually get rid of the noise or it would have been an expensive waste of time.
Matt
_uctorry_
Posted 21 July 2011 - 09:26 PM
had the same problem in my hatch
went to iron case and fixed the problem
cheap alum cases causes more wear and noise than iron cases
hope this helps
Stuart
Posted 21 July 2011 - 09:32 PM
_outer control_
Posted 22 July 2011 - 05:01 AM
Yeah I had some tyre noise in the rear which everyone swore was bearings, maybe absolutly rule out any other possible cause.
Its a Ford product
Posted 22 July 2011 - 08:45 AM
people always seem to forget the 9in is a heavy duty truck diff (and was slightly noisy in trucks anyway)and when modified into smaller cars you always get some noise..hi guys looking for any help
Chris
generally speaking if use factory ford gears they can be less noisy even worn my diff guy tells me something to do with the metal ford used...
i've used all the after market stuff including strange,richmond and motive gears..richmond are by far the most noisy...i find you'll always experience noise especially when going up the ratio's 3.77s and upwards ..motive gears are by far the less noisy one's on the market..
Posted 22 July 2011 - 06:42 PM
Step 2, change oil to a straight 140 weight and add friction modifier of your choice. I have used the ford motorsport and nulon stuff with good results.
Step 3, add undercarpet insulation, preferably double layer bitumen containing stuff.
If you still have a bothersome noise then your gears may be at fault (or wheel bearings/unis etc..)
In my experience none of the cars with 3.7s or less eg 3.25 should have an audible whine from inside the car.
Good luck.
_slr5000.com.au_
Posted 22 July 2011 - 08:41 PM
i have motive performance gears in it this time and it is better just still more than what i would call acceptable. 3.9 ratio previous 3.7 and 4.11
tyres are ok but i will try anything at this stage
i have replaced all bearings axles diff
also have double layer dynamat all through the car
has anyone had any noise transfer problem through trailing arms, as springs do sit on rubber but it also has nolothane trailing arm bushes.
Step 1, borrow some rear wheels and tyres from a quiet car and see if your noise goes away.
Good luck.
Posted 22 July 2011 - 09:23 PM
Rare Spare now sell reproduction spring to body insulators H1117 REAR SPRING INSULATOR KIT HQ-HZ, LH-UC.
Edited by ls2lxhatch, 22 July 2011 - 09:24 PM.
Posted 23 July 2011 - 12:35 PM
as was mentioned before the best gearsets to use are the genuine ford and ford motorsport gear sets.
iv used iron and alloy housings, havent noticed a difference between the two.
_slr5000.com.au_
Posted 25 August 2011 - 08:02 PM
new tyres
and a new centre with true track brand new gears bearings ect. 4th different centre .
has any hone had the housing cause a problem ?
_Ozzie Picker_
Posted 25 August 2011 - 08:15 PM
how much noise are we talking about,i,ve never had a problem with my 9 inch,but my exhaust is noticable,i have changed ratio,s for different purposes,with no noise problem,low ratio,high etc.
are you sure its the diff,what type of gearbox do you have,i just find it hard to beleive after so many changes of centres,its still noisy,why carn,t the diff shop fix it,or are they just taking your coin.
Posted 25 August 2011 - 10:29 PM
Gear boxes yes, other driveline components yes
I would get a second opinion or beg, borrow and err... off some mates and substitute driveline components till I eliminated the noise
_slr5000.com.au_
Posted 27 August 2011 - 12:04 AM
it very much seems like gear noise and we are not talking a small amount it is very loud and increses with road speed 60k noticeable 80k very loud 110k can still hear it even with sterio cranked.
i have had the diffs build by a very well known buisness in adelaide and even they are scratching to explain the problem.
i should be able to borrow a diff centre from a mates car that is quiet next weekend see how i go.
gear noise
I've had qiute a few 9 inch diffs in various models falcons and in a couple of Holdens, none ever had noise problems, ratios from 2.78 to 5.14
Posted 27 August 2011 - 12:40 AM
My 3.9 9" is quiet as. Cant hear it.
_slr5000.com.au_
Posted 27 August 2011 - 09:48 AM
also axles have no problem going in still maybe it is enough to cause noise .
Is the housing bent???
_slr5000.com.au_
Posted 27 August 2011 - 03:03 PM
i thought of that but wheel alighn is fine wich i thought would be out if bent ,
Posted 27 August 2011 - 03:30 PM
#21
Posted 27 August 2011 - 04:06 PM
An educated guess would be 0.
+1
no toe in or toe out on a live rear axle.
#22
_gearex_
Posted 29 August 2011 - 03:10 PM
#23
_slr5000.com.au_
Posted 30 August 2011 - 10:59 PM
you can see why im puzzled have tried just about everything.
any ideas appreciated tho
cheers chris
do you have Nolathane bushes in the rear? that can be a noise factor, or another silly thought, are you sure its not the gear box thats noisey?? I have had seen that problem a few times.
#24
Posted 30 August 2011 - 11:05 PM
This could probably be enough to cause mechanical/and/or/tyre noise.hey guys just had car wheel alighned again and rear has 4.5 mm - toe
#25
_77hatch_
Posted 06 September 2011 - 11:16 PM
if you have tried that many gear sets & diff centres , i would look elsewhere for the problem ?!
"hey guys just had car wheel alighned again and rear has 4.5 mm - toe [/quote]
This could probably be enough to cause mechanical/and/or/tyre noise."
