Steering Column Shroud?
4 replies to this topic
#1 _Mr_Lj_
_Mr_Lj_
Posted 19 August 2011 - 12:30 PM
Hey all, I would just like to know how to pull off the steering column shroud on my 73 LJ so i can paint it?
Is it hard ?
and whats involved in taking it off?
Any help would be great !!
jamie
#2 _Mr_Lj_
_Mr_Lj_
Posted 22 August 2011 - 06:29 PM
No one knows?? is this a stupid question or something??
#3 limo
limo
  • 2,673 posts
Posted 22 August 2011 - 08:20 PM
lot of steps, 4 speed or T bar (different if 3 on tree or column auto)
take off steering wheel
remove indicator stalk
undo screws for indicator unit
unplug wire form at connector under dash
take out screw and remove form clip
take indicator unit out, need to slide form up through steering column
remove screws for top section of column with key and lock
slide this up and off
now you are at the lower section
remove the 2 screws at base of the shroud and slide up and off
if I missed something my apologies but this from memory
replace in reverse order.
have a good time
#4 S pack
  • 15,728 posts
Posted 22 August 2011 - 11:04 PM
have a good time
Also undo steering column to dash support bracket, lower column, unplug wiring from ignition switch, undo bolts and remove ignition switch from column and disengage switch from actuator rod. Remove circlip and spring from top end of steering shaft. Then you can remove the coffee pot.
#5 _Mr_Lj_
_Mr_Lj_
Posted 23 August 2011 - 08:15 AM
Thank you !! at least i know whats involved now :)
