Difference between VE chaser rims and VL to VZ
25 replies to this topic
#1 Bart
Bart
    Shit a brick
  • 2,559 posts
  • Car:LJ Torana
Posted 02 September 2011 - 09:41 PM
Basically I want to use 16" chasers, Im planing on using VS style Commodore Hubs and would like to know if the VE's will fit. Dont they have different size studs?
#2 Statler
  • 6,329 posts
Posted 02 September 2011 - 09:46 PM
Different size centre bore
#3 _Bomber Watson_
Posted 02 September 2011 - 09:47 PM
Pretty sure VE is a totally different backspace to earlyer commy's.
If your willing to cut/reweld then shouldnt be an issue.
#4 dattoman
Posted 02 September 2011 - 09:51 PM
Early Commodores are 12mm studs
VE are 14
Centre hole size is different
SO too is offset
So all the above are correct
#5 Bart
Bart
    Shit a brick
  • 2,559 posts
  • Car:LJ Torana
Posted 02 September 2011 - 09:52 PM
Thats right, i remember someone saying the centre needs to be machined out a little.
May be easier to use VE style hubs but dont know if they are available as the VS ones are for HQ style stubs
:surrenderwave:
#6 Bart
Bart
    Shit a brick
  • 2,559 posts
  • Car:LJ Torana
Posted 02 September 2011 - 09:56 PM
VE are 14
SO too is offset
Oh bugga, not so simple
Hey Datto, would you know if there are VE style hubs for the HQ stub axle as there are VS style hubs for the HQ stub??
I guess redrilling the VS hubs and using VE studs would be one way then machining the rim centres, but hey they are just steel rims at the end
#7 _Gunmetal LH_
_Gunmetal LH_
Posted 02 September 2011 - 10:31 PM
Maybe machine the hub centre down to suit the VE wheels centre holes and use a flanged sleeve (so the wheel will hold it in) to 'thicken' the hub if you use VZ or earlier wheels on?
Legalities? Dunno?
Edited by Gunmetal LH, 02 September 2011 - 10:37 PM.
#8 _Bomber Watson_
Posted 02 September 2011 - 10:43 PM
That part of the hub center supports the outer bearing????
Unsure i would machine much off it??
#9 dattoman
Posted 03 September 2011 - 12:12 AM
Why would someone make a VE style hub to suit a HQ ?
Thats crazy talk
How about you convert to Ford stud pattern and use Terrotry wheels... hahahahaha
But yes you could machine the hub to suit the later wheels
Use big studs too if your worried about it
I think offset is your biggest problem
As with any style of Commy wheels on a RWD early Holden
Commy use stupid FWD offsets from day 1
#10 Bart
Bart
    Shit a brick
  • 2,559 posts
  • Car:LJ Torana
Posted 03 September 2011 - 07:55 AM
Thanks guys that a few options.
Datto, i figured there may be VE hubs for HQ stubs like the VS hubs for HQ stubs. But you may be making a set right?? :stirpot:
#11 _V6 UC_
_V6 UC_
Posted 03 September 2011 - 08:16 AM
I have the 16x7 ve chasers on my UC. As above I had the centers cut n rewelded and the hub machined out 3mm. Cost me 50bucks a rim, keeps a subtle look and let's me run 245s on the back. I am using vn diff standard stubs with hq rotors on front. Have been on the car for 25000km no issues
#12 Bart
Bart
    Shit a brick
  • 2,559 posts
  • Car:LJ Torana
Posted 03 September 2011 - 08:23 AM
So you welded in HQ cetres into the VE rim? After removing the VE center?
Why did you machine the hub?
#13 _V6 UC_
_V6 UC_
Posted 03 September 2011 - 08:27 AM
Because they are a steel rim I was advised by the engineering mob that I will b able to get away with the commy to hq as it's on The front and no power transferred and only a thin section like 3-mm that slides over. Sorry meant the hole on the rim was machined out 3mm to go over becausethe ve is 3mm smaller. Have a look at my build it's one or 2 pages in on the members rides
#14 Bart
Bart
    Shit a brick
  • 2,559 posts
  • Car:LJ Torana
Posted 03 September 2011 - 08:48 AM
I will check out your build, but what did you do about the studs, the VE stud holes are 14mm
#15 _V6 UC_
_V6 UC_
Posted 03 September 2011 - 09:05 AM
Yeah the wheel nuts I have have got a nice deep chamfer which protrude into the hole by about 2-3mm so they work well. Have done plenty of events and about 30 qtr mile passes on these
#16 Bart
Bart
    Shit a brick
  • 2,559 posts
  • Car:LJ Torana
Posted 03 September 2011 - 09:13 AM
What nuts did you use? Custom nuts or Commy?
#17 _V6 UC_
_V6 UC_
Posted 03 September 2011 - 09:25 AM
Pretty sure they are just a common mag nut
#18 DanWA
DanWA
  • 2,440 posts
  • Car:LS1 LX 4 Door
Posted 03 September 2011 - 10:17 AM
I was going to get my bro to machine the centre out then try these on my torana, see how i go with offsets (r31 diff and hopper stoppers kit)
Edited by DanWA, 03 September 2011 - 10:17 AM.
#19 _glenn l_
_glenn l_
Posted 03 September 2011 - 10:31 AM
the chasser wheels on the vy/vz crewman and one tonners are 16", you wouldnt have to worry about machining the center out and stud size, had one as a spare for my vn because i had 330mm brakes on it.
#20 Bart
Bart
    Shit a brick
  • 2,559 posts
  • Car:LJ Torana
Posted 03 September 2011 - 10:38 AM
You just saved me from splitting my balls
My question should have been, are there any 16" chaser Commy wheels haha
I guess sometimes it takes a process to get all the info.
But this is great at least we all learn something
Thanks Guys
Edited by Bart, 03 September 2011 - 10:42 AM.
#21 Bart
Bart
    Shit a brick
  • 2,559 posts
  • Car:LJ Torana
Posted 03 September 2011 - 12:22 PM
Just one problem, they're bloody hard to find (16" Crewman wheels) :Headbang2:
#22 dattoman
Posted 03 September 2011 - 02:22 PM
http://www.motorfield.com.au/index.php
#23 _shan620_
_shan620_
Posted 03 September 2011 - 03:15 PM
buy blanks like im doing and get brake place to drill what ever stud pattern u want.
#24 Bart
Bart
    Shit a brick
  • 2,559 posts
  • Car:LJ Torana
Posted 03 September 2011 - 06:05 PM
You mean blank VE rims?
Where do you get blanks? How much?
Edited by Bart, 03 September 2011 - 06:07 PM.
#25 dattoman
Posted 03 September 2011 - 06:09 PM
No
No blank rims
