Difference in t04 turbos
_mike_nofx_
Posted 29 November 2005 - 08:18 PM
Like, whats the difference between a t04e or a t04b?
_ToranaGuy_
Posted 30 November 2005 - 12:25 AM
Do a few searches on google, and you will find the info your looking for. But remember one thing, just knowing the type, eg T04B or T04E doesn't mean much, you need to know the a/r's and wheel sizes as well. Also if it's oil, water or both cooled. Mine is oil cooled.
ToranaGuy
_mike_nofx_
Posted 30 November 2005 - 03:00 PM
Whats the numbers mean?
Mines a AiResearch T04
_jap-xu1_
Posted 30 November 2005 - 08:44 PM
Edited by jap-xu1, 30 November 2005 - 08:45 PM.
_ToranaGuy_
Posted 01 December 2005 - 12:01 AM
I found this on my wanderings around the net about a/r sizes.
A/R
A/R describes a geometric property of all compressor and turbine housings. Increasing compressor A/R optimizes the performance for low boost applications. Changing turbine A/R has many effects. By going to a larger turbine A/R, the turbo comes up on boost at a higher engine speed, the flow capacity of the turbine is increased and less flow is wastegated, there is less engine backpressure, and engine volumetric efficiency is increased resulting in more overall power.
I'm going to play with my setup the way the turbo is atm, and if i get hungry for boost lower in the rev range, i'll build a hybrid T04.
ToranaGuy
_jap-xu1_
Posted 01 December 2005 - 09:02 PM
yes it was an rb30 (3.0l/186ci) and hit 18psi at 3500rpm
_ToranaGuy_
Posted 01 December 2005 - 11:49 PM
The online calc i used musta been off a bit.its 250rwkw.
18psi, any work to the cam or comp ratio?
ToranaGuy
_jap-xu1_
Posted 02 December 2005 - 07:24 PM
kw to hp = 1.341
Edited by jap-xu1, 02 December 2005 - 07:25 PM.
_ToranaGuy_
Posted 03 December 2005 - 01:49 AM
Very interesting!not much, just more duration on the cam with zero overlap.1mm more lift.
kw to hp = 1.341
ToranaGuy
