lc 4 to 6 cylinder conversion
24 replies to this topic
#1 _doubletake2_
_doubletake2_
Posted 09 October 2011 - 08:56 PM
Howdy,
I'm about to start converting my 4 banger lc two door into a 6 and swaping the front end,has anyone done this on here,I have a basic idea what's involved could you guys give me any hints towards it. Cheers daryl
#2 Potta
Posted 09 October 2011 - 11:29 PM
I don't think its really been done because its a lot harder than you might think.
Good luck with it though.
I once had the same dream, until I realised it would have been easier to get a 6 cylinder to start with.
#3 _doubletake2_
_doubletake2_
Posted 10 October 2011 - 03:49 AM
Lol cheers mate8-),do you know if the sub frame is the same.
#4 r2160
r2160
  • 712 posts
  • Name:Glenn
  • Car:2/71 LC GTR, 4/71 LC 4 'S'
Posted 10 October 2011 - 07:43 AM
You would at least have to graft an entire front end onto the car. It would probably work out a lot cheaper just to buy a 6 cylinder shell and go from there.
Unless you planned on cutting the firewall and moving the engine back. There was actually a torana at "Toranafest" that had done exactly that.
Glenn
Edited by r2160, 10 October 2011 - 07:43 AM.
#5 _doubletake2_
_doubletake2_
Posted 10 October 2011 - 07:52 AM
I was thinking of moving the cross member foward and changing everything from the firewall foward to a 6 front end ...maybe
#6 r2160
r2160
  • 712 posts
  • Name:Glenn
Posted 10 October 2011 - 08:04 AM
By front end, I mean inner and outer guards, the radiator support panel, the whole lot. I am not sure of how the front suspension compares to the 6 cylinder version. I would guess that the brakes would be larger as well but you would have to check on that.
The other alternative might be to get a nice little four banger and graft it in there if you are after a little more performance. Perhaps a 4AGE corolla twin cam or the like
glenn
#7 _doubletake2_
_doubletake2_
Posted 10 October 2011 - 09:07 AM
Yes I was thinking the gards and all and using a 6 cylinder cross member, I may have a donor sedan soon, time and effort is no problem.I have no completion date lol. Cheers daryl
#8 dattoman
Posted 10 October 2011 - 10:04 AM
Would be easier to turn the donor sedan into a 2 door
#9 _doubletake2_
_doubletake2_
Posted 10 October 2011 - 11:36 AM
Ok:) ,interesting never though of that how would I do it ,daryl
#10 dattoman
Posted 10 October 2011 - 04:01 PM
Theres a thread here on doig exactly that
Try the panel and paint or fabrication section
They are the same shape and roofline... so its moving B pillars and grafting bits on
But "looks easy"
#11 _doubletake2_
_doubletake2_
Posted 10 October 2011 - 07:41 PM
I have read the thread, think I might atempt changing the frontend,cheers daryl
#12 Toranamat69
Toranamat69
    Forum R&D Officer
  • 2,117 posts
Posted 10 October 2011 - 07:56 PM
The chassis rails and rear suspension mounting points are different also.
#13 _Bomber Watson_
Posted 10 October 2011 - 08:11 PM
Firewall needs unpicking and everything from there foward replacing. Front X members are not interchangeable. nothing is the same. And as said the rear suspension is totally different as well.
#14 _doubletake2_
_doubletake2_
Posted 10 October 2011 - 08:17 PM
How much diffrent is the chassis rails
#15 _Bomber Watson_
Posted 10 October 2011 - 08:18 PM
At the front end there totally different. Rear end is also different aroudn where the suspension mounts. Unsure about the middle.
#16 _doubletake2_
_doubletake2_
Posted 10 October 2011 - 08:29 PM
Is it possible tounpick the chassis rail ,or some how replace it ,I have an exploded diagram of how obody goes together but it doesn't show how the chassis attaches to the subframe
#17 _Bomber Watson_
Posted 10 October 2011 - 08:31 PM
Dunno, never tried.
for the couple of hundred hours probably required i'd personally prefer to just buy a six cylinder one or graft a hot four into it.
#18 _doubletake2_
_doubletake2_
Posted 11 October 2011 - 07:08 AM
I've slept on the idea,starting to think you guys are right adout converting the 4door to a 2 door and not worrying aBout the 4cylinder,ill use all the pannels and doors off the 2door(4cylinder)that's if I'm lucky enough to Buy the 4 door I'm looking at, cheers daryl
Just need to talk to an engineer
#19 _73LJWhiteSL_
_73LJWhiteSL_
Posted 11 October 2011 - 03:15 PM
I used to laugh at people suggesting what I am about to, but then I owned a SSS Pulsar and came to an understanding.
Stick a SR20 in the Four cylinder LC and it will go HARD. :3gears:
Don't get wrong having a Holden 6 in a Torana is the best way, but those SR20s make heaps of power and return quite good economy.
Steve
#20 _Agent 34_
_Agent 34_
Posted 11 October 2011 - 04:06 PM
Double take 2;
I have got the following;
2 x rear quaters - not bad condition - from Lj
1 turret roof off 2 door
1 rear parcel shelf and rear beaver
bought these off a guy that was turning the car into a drag car, can still be used to go onto a 4 door conversion.
I also have a Jl TA 4 cylinder - two door, that i am chopping up for the rear quaters for my car. the rails and rear suspension are all different and stuff. I do know someone who has replaced the rails.
whats left will be the some of the side internal panels and supports for the two door conversion as the four doors are different.
let me know if you need anything.
I'd just buy a 2 door in reasonable condition and do the rust repairs and then paint, it a big job and expensive to do that type of conversion to a standard two door. it's even getting nearly not worth it for the gtr im doing.
have a long think about this one. save your money is my advice unless that car is worth 40 K plus in the end.
three cents
#21 _doubletake2_
_doubletake2_
Posted 11 October 2011 - 08:01 PM
Thanks mate, ill put some serious thought into the conversion,thanks for your offer but I already have a 4 cylinder 2 door lc ill use all the pannels needed of it,but ill keep you in mind if I need something.cheers daryl
#22 orangeLJ
Posted 13 October 2011 - 08:53 AM
Id honestly just keep it a four door... :dontknow:
#23 _Ben_
_Ben_
Posted 13 October 2011 - 09:08 AM
I agree.
#24 _Bomber Watson_
Posted 13 October 2011 - 06:19 PM
We know four door ones are the best.
#25 ant285
ant285
  • 143 posts
  • Name:ant
  • Car:lj
Posted 16 October 2011 - 06:43 PM
i too was gona do this conversion. bought a lc 2 door 4 cylinder that came with a 6 cylinder front end. started unpicking all the firewall spot welds and then realised the chassis rails are different widths. so just ended up buying a lj 6 cylinder 4 door. serious amount of work involved also engineering reports and stuff. would work out cheaper just to wait for a rusty 6 cylinder 2 door i think.
cheers ant
